Longitudinal Acceleration Sensor
Routledge Nov 8, 2011
  1. Routledge
    Routledge Wind Deflector Trend-setter
    392
    10
    My hopes of needing a new ABS sensor have been quashed by VAG COM telling me that I have a sporadic issue with my Longitudinal Acceleration Sensor.
    I believe Audi charge over £100 for a replacement, but am wondering if there's anywhere else I may be able to get one from?
    It's probably not even worth buying a second-hand one as I believe they've got to be programmed in via a full VAG COM unit and for it to become faulty 3-6 months later is wasted money.
  2. Routledge
    392
    10
    It's for a 2000-plate pre-facelift S3, btw.
  3. Westy
    Westy Well-Known Member
    17,443
    1,103
    I have bought Wheel speed sensors from Euro Car Parts before that have only lasted 3 months and I've only saved myself maybe £20.
    My advice would be to buy a genuine one. You buy cheap and you buy twice, trust me.
  4. Routledge
    392
    10
    I called up Euro Car Parts and they said that they wouldn't even do me the sensor that I need and that I'd need to go to a dealer direct.
    Looks like I'm paying out >£100 then + labour.
  5. Westy
    17,443
    1,103
    Forget labour mate. Change it yourself it's fairly straight forward. I'll try and find a guide.
    Also try getting a quote from Stoke Audi on here as it might be slightly cheaper than your local dealer and he can post it to you.
  6. Jordysport
    Jordysport Member
    59
    mine was £131 from TPS, and took 5 mins to change i did it in the carpark outside TPS actually :p
  7. Routledge
    392
    10
    Ah right ok - Yeah I thought you had to have them programmed in but if it's a 5 minute job then all's well! I've been researching it all day and have found where they are located (I believe by your left knee on pre-facelift on the passenger footwell up front).
  8. Jordysport
    Jordysport Member
    59
    Remove the Glove box (a few bolts) take off the dash end panel (open passenger door) it pulls off. remove the multiple torx/bolts and the inner panel will come off, can get at the sensor then, i found it easier to remove it with the bracket then change it and put it back. then after that first time i started it the light never came back on. happy days
  9. s3matty
    s3matty Member
    166
    Well what about the sensor under the steering wheel?
  10. oubas2
    oubas2 New Member
    14
    ive got one of these in the workshop, PM me for details
  11. Jordysport
    Jordysport Member
    59
    the lateral sensor you mean? if you mean longitudinal sensor then some i believe are under the steering colomn but mine a facelift was still on the passenger side.
  12. Routledge
    392
    10
    PM Sent
  13. Sam_
    Sam_ Down under
    3,038
    480
    Facelift ones are under the steering wheel which makes life a bit easier. Mine had a bent bracket so wasn't sitting completely flat. Worth noting there's a calibration feature in vagcom for them also.
  14. Jordysport
    Jordysport Member
    59
    Mine is a facelift and it was behind the glovebox...
  15. Sam_
    Sam_ Down under
    3,038
    480
    Very odd - everywhere I've read (and mine) has both sensors under the steering wheel. Is yours an 01?
  16. Westy
    17,443
    1,103
    There are 2 sensors I think one is under the glove box and one under the steering wheel. Logitude and latitude sensors???
  17. Sam_
    Sam_ Down under
    3,038
    480
    I thought this originally then was told that on facelift there's a "dual sensor" (yaw and latitude) and then a longitudinal sensor (G200).
  18. Routledge
    392
    10
    All sorted. Getting one bought and fitted all-in for £50.00 on Saturday.
