Long Life Service?
Ash B Dec 18, 2008
  1. Ash B
    Ash B Well-Known Member
    5,831
    84
    Can any on explain what it is? What do they actually change on the car or top up? Is it like just any other service?
    Ashley
  2. Matt
    Matt Active Member
    1,404
    Think its just the same as any other service as long as the cambelt or anything like thats not due. They just put the "longlife" oil in instead of normal oil?
  3. Ash B
    5,831
    84
    Hi matt
    That what i was thinking just different oil...So when they service your car do they top up the brake fluid and de-bug and re-gas the air con? My car was serviced in March at my local dealer in Cardiff.
    But yesterday had to pay £155.85 for the brake fluid and de-bug and re-gas the air con?
    Ashley
  4. Matt
    Matt Active Member
    1,404
    Mine hasn't had its 1st service yet so not had the list of whats done.
    Does it not say in the service manual about the brake fluid change intervals?
  5. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    I think the brake fluid change is every two year and is a chargeable extra service item.
    Paul
  6. Ash B
    5,831
    84
    I'll have to have another look but from what i can remember from the last service in march doesn't say any thing about it. So it would of been due the start of this year.
    will check later and post thanks Matt & Paul
    Ashley
  7. Jo Sharp
    Jo Sharp Member
    131
    On a standard service they will check the brake fluid level and top-up if needed. They will only change the fluid completely if you agree to it when you take the car in. Air-con is not part of a normal service schedule - it is an additional item.
  8. h5djr
    9,421
    1,746
    Brake fluid is normally only changed every 2 years. The need to change it is age related rather than miles. The brake fluid absorbes some moisture over time and 2 years is regarded at optimum time to change.
