Logs I did for Bill Badger 5 with my hybrid set up.
S3 Paul May 19, 2012
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    After Seeing the issues Dave had with his Hybrid set up...
    It started to bother me that mine can and does do some strange things but pulls ok...
    In the RS tuning thread Dave started Bill mentioned some measuring blocks to log...
    Here are my logs in 3rd of these units... can somebody check them over please ?
    To me they look slightly worrying
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    First thing I've spotted is in your first spreadsheet. Fuelling is lean at the top of the rev range on boost. You have an AFR of 10 where the map is requesting a 13. This suggests to me that the fuel pump is struggling at the top end.
    What injectors do you have Paul and do you have an inline pump fitted?
  3. S3 Paul
    2,825
    107
    Sorry, it looks like ive cocked up and double posted one log.
    I will try and find the third
  4. S3 Paul
    2,825
    107
    I dont have an inline pump .
    I had a problem about a year back with my fueling... so fitted a new standard pump. Relogged and all seemed well.
    Im using standard injectors and a 4bar FPR
  5. Westy
    17,443
    1,105
    Did you log EGTs anywhere? It could be EGT protection.
  6. Westy
    17,443
    1,105
    Sorry I meant rich not lean! Still waking up.
  7. badger5
    9,599
    2,060
    i would be wondering why the throttle is pulling back and closing at 4800rpm on last logs..... boost deviation at same time (more actual than request at same kind of time stamp)
    fueling wise, the logs are short to see any stable sort of requests... but uts 3rd gear and high speed so I understand its not going to be easy doing 4th gear run
    logging 001 and 002 and 031 on a longer pull would show how well the fueling is doing... and if the maps having to adapt a lot to achieve its tgt fueling request...
  8. S3 Paul
    2,825
    107
    the car pulls well ( probably to be expected if its lean )
    The boost can spike to nearly 30psi ! but i kind of have to drive ina given way to make it do this.
    Since bill checked my logs with new pump ive changed 2 things ( nothing major) ive done the N249 delete and fitted a Jetex cone filter,
    Hen things like this get highlighted i stop loving the car,
    Until now its been good,
    Ive fitted an AFR gauge for peace of mind, A local tuner mentioned it was a little lean at full tilt, I posted up what numbers i was getting and tuffty said they are fine?
    Sorry, just read your post... im running rich?
  9. S3 Paul
    2,825
    107
    Would an uphill pull be better? i struggle to find a road thats quiet and straight enough to burry to the red line...
    If need be i could pay to use a mates dyno ? but he isnt a vag man so other than what you tell me im flying blind
  10. Westy
    17,443
    1,105
    Not rich sorry but fuel dump on your figures on the first spreadsheet suggesting EGT protection. Bill didn't mention it though.
  11. badger5
    9,599
    2,060
    uphill yes.. and 4th ideally..
    which blocks did I say... I cant find that post... you have done a few but not many of them I think
  12. Dani_B19
    9,381
    403
    Take it down morrisona bypass utpo hoyland mate, thats nice and lengthy
  13. S3 Paul
    2,825
    107
    Bill...
    You surgested
    003 115 118
    002 020 031
    003 112 118
    Sorry i think in the dark and heavy rain we got a little mixed up and missed one set of blocks,
    Dan
    Ive run the car there many times in my dafter years but its such a hot spot for police these days. no end of people i know have had there cars towed away by them.
    Bill, you mentioned the throttle looking like it shut off half way into a pull,
    Im not sure if hitting a big patch of standing water would make the Haldex system shut off the gas slightly? or my balls shrunk a little?
    Ive spoke to the company i know localy that mainly do Jap cars ( i do some CNC work for them ) and the owner is happy to let me pull a few runs on his dyno as a favour, Im unsure yet if the road is better but i will log again whatever you need to see,
    Many thanks all.
  14. Dani_B19
    9,381
    403
    What about the grimy bypass? Thats pig free! Trust me i know haha
  15. S3 Paul
    2,825
    107
    Up near Sash?
    Ive only been on there once.
    Also need a co piolot for these trips
  16. Dani_B19
    9,381
    403
    No up near morrisons, near sash on grimy bypass is too flat but should benok, if you need a need hand drop me a text mate.
  17. badger5
    9,599
    2,060
    ok ta for the reminder..
    if fueling (or pump) is suspected... then log 001 as well as 031 and 115 so if its having to dial in a higher % on 001 to achieve the requested fueling on 031 you will see it
    dyno runs would be fine (and safer) to do longer pulls - I use 5th here
  18. Dani_B19
    9,381
    403
    Well if you need a hand mate let me know and ill log while you drive.
