Logs help
s3gazz
bradford
Just done some logs, please can anyone tell me if something is not right, keeps going into limp mode under full boost,
1 fault boost deviation check dv......cleared and did this log.
how do you reset the throttle adaption via vcds
cheers guys
Saturday11December201012:42:138N0 906 018 J1.8L R4/5VT 0004Group A:'032Group B:'115Group C:'003LambdaLambdaBin. BitsBin. BitsRPMLoadAbsolute Pres.Absolute Pres.RPMMass FlowLoadIgn. TimingTIMETIMETIMEMarkerSTAMP%%STAMP /min% mbar mbarSTAMP /min g/s% °BTDC0.42-3.2-0.80.914200167.7229018600256062.7897.3181.71-3.2-0.82.1357609.8121014501.315200174.56100213.02-3.2-0.83.424760188241022302.623960121.6910022.54.24-3.2-0.84.646000170.7227019503.825200183.86100155.45-3.2-0.85.934640136.8240016005.046360198.06100156.75-3.2-0.87.155240180.5237021506.354760173.0610012.87.95-3.2-0.88.355760170.7223021307.555400188.72100129.17-3.2-0.89.57608051.1100023008.755920192.6999.612.810.37-3.2-0.810.77528012.8100010909.97596012.117.17.511.57-3.2-0.811.98448012.81000104011.17496012.696.74.512.88-3.2-0.813.39380012.81000103012.38428010.865.53.814.28-3.2-0.814.82800151000103013.8835609.084.3315.69-3.2-0.816.09116015.81000102015.222806.312.72.323.44-3.2-0.823.852880100.82170118024.353760103.7810024.824.75-3.2-0.825.155720172.22350203025.55556012.753.96.825.96-3.2-0.826.464720181.22370215026.865240177.9210014.327.37-3.2-0.827.776280172.22150202028.176640195.1910015.828.59-3.2-0.829.074720120.32290133029.4848009.397.82.329.88-3.2-0.830.28456012.81000114030.68436012.116.33.831.08-3.2-0.831.59392013.51000105031.9937609.814.73
how can i get the excell screen posted properly....
Screen shot, host the image and link to/insert into post....
Like this...
Only highlight the data captured during the run rather than all the stuff around it
****** me! what gear did you do that in? needs to be in at least third to get decent resolution and use blocks 031, 020 and 115 initially... no need in logging 032 and no point in loggin airflow just yet...
first half up to 3 was to number 17 and second half was second gear is that good or bad by the looks of it mate
Can't tell without a proper logging run... log blocks 020 (timing pull), 031 (fuel request vs actual) and 115 (boost request vs actual).... do the runs(s) in third gear (only) start from about 2000 rpm and put your foot flat to the floor until as legally/safely close to the redline you can get... the engine MUST be at proper running temps (90 degrees)... only post the run data :)
BTW, what engine code is your S3? I only ask as there is no point logging block 031 on early non wideband lambda S3's... AMK or BAM and you are fine...
ok cheers tuffty ye ill do all them tomoz my engine code is amk mate
958
868
747
