Locking wheel bolts.
wanton May 19, 2013
  1. wanton
    wanton Member
    234
    14
    Hi All,
    I should be getting my A3 next week. I have decided because the rims are in good nick I am going to add another set of locking wheel nuts. When I put my vehicle details on the Mcgard site (A3 2006) it comes back with 28018SU the better version are the 28018SL which have the same dimensions but are strangely not given as an option when I do a search on my car. The problem is I have the 18" 20 spoke alloys which were an upgrade and I don't know if they use the standard bolts or if the bolts are longer or have different dimensions from the standard ones. Does anyone know?
    Cheers.
  2. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    By 20 spokes, do you mean OEM Speedlines? If so, as long as you've not got spacers on, you'll need the following bolts...
    Thread = M14x1.5
    Seat = Radius
    Head = 17mm
    Length = 27.5m
  3. wanton
    wanton Member
    234
    14
    Hi Leeds,
    I dont know the name of them but they were a factory upgrade. I presume there would not be any spacers fitted as there would be no point. Is that about right?
  4. immo
    immo Stop me
    275
    40
    Pictures speak a thousand words..
  5. wanton
    wanton Member
    234
    14
    Ok here are some pictures. :sm4:
  6. Boon
    Boon Active Member
    441
    59
    When you say you want to add another set, do you mean there are already locking wheel nuts on there & you want to make it so you have two locking wheel nuts per wheel?
    I wouldn't advise it if that's the case, they are not as strong as normal wheel nuts & could cause you problems
    Other than that just go with the ones McGuard recommend for you vehicle, if they are OEM wheels you will be fine
  7. wanton
    wanton Member
    234
    14
    Oh I didn't realise the locking bolts would not be made of a similar strength steel. Might have to leave it then. Hopefully the alarm I want to get fitted will deter any thieves...
