Locking Nut Key - Mangled! Need replacement and help ASAP!!!
tates1979 Feb 3, 2011
  1. tates1979
    tates1979 Member
    52
    Right folks - MOT on Thursday of next week.
    Need 2 new tyres on the back wheels (standard 16" - original wheels).
    The wheel on the back left was ceased on and the locking nut key sheared and came off - now i cant get the wheel off!
    So i will need a replacement nut key to get the wheels off in the future (don't care about locking nuts in the future - they're the bog standard ones) - apparently there are several different iterations of the key - my one has seven spokes to it (if you get my meaning) - is there any way of identifying which one i need? I don't want to go to the Stealers and get charged an astronomical fee!
    Thanks in advance for your help
    :crying:
  2. hades-
    9,481
    646
    local tyre shop will get them off for a few quid
    and supply you with new bolts to replace the lockers
  3. Cyrix
    Cyrix Member
    292
    23
    I've a full set of genuine wheelbolts/locking bolts with key on ebay currently......
    As for removing them, find a multi-point socket slightly smaller than the locking bolt, attach socket to an extension bar, hit extension bar with large hammer until it is forced onto the key then remove as you would a normal bolt.
    I think the last time I had to do this it was either a 17mm or 19mm socket, in typical fashion the locking key appeared about 5 mins later.......
  4. phil76
    phil76 Active Member
    572
    40
    The dealers can match your locking nut key up and order one as there are only so many different patterns
  5. PaulTheo
    PaulTheo Member
    126
    Try here Home - ZakParts you can work out which key you need from the pictures as well.
