My PDC has been playing up recently so took it to have the fault codes read.
All the sensors are doing the "click when you listen to them" trick but the full scan of the system has shown up a code as follows:
1543 - Rear parking aid warning buzzer H15
Open circuit/short circuit to earth
As my reverse buzzer had been sounding a little ropey recently this makes sense.
The question is - where is it located and is it easy to get at to remove?
Also, any thoughts on what might be causing this with the buzzer - could it just be a loose connection?
Thank you
Thank you
