location of central electrics module?
scottie123 Feb 18, 2010
  1. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Anybody know where it lives in the 8p? And what is the best way to get at it.
    Also, would it be pushing my luck to ask what repair wires would be needed to add pins to connectors A,D and E ? :)
  2. JohnS3
    JohnS3 Active Member
    3,032
    It's under the drivers side of the dash. Take the cover off the fuse box, remove the bolt (There's two more underneath.) that holds the lower cover around the headlamp switch. Look under the dash and you'll see a large box with many plugs in it. This is your CE unit.
  3. JohnS3
    3,032
    The repair wire is probably 000 979 009. One repair wire has a plug on both ends.
  4. scottie123
    1,972
    Thanks John.
