Little niggle, outside door handle trim coming away (photos)
paul_r Jan 14, 2011
  1. paul_r
    paul_r Member
    172
    Hi
    My A3 drivers door has a bit of trim that will not sit tight as it should. I would guess i am not the only person to suffer this. See pics. Any simple remedies. I guess i could just glue it in place. As it is it just keeps springing out and i am in the process of sorting all the little issues i have with my car.
  2. moag
    moag she's no d-turbo
    821
    35
    araldite should fix that!
  3. 19scotty81
    19scotty81 Push down and across !!!!!!!!!
    107
    Is it just the trim that's coming out or the door barrel itself.
    You can sometimes get it to click back on with firm pressure but if the clip is broken you'll need to replace it. Best way to check though just wip the barrel out, just inside the door there's a little plastic cover, remove it and you'll see a 15 (maybe's) torx screw,unwind the screw until you feel it getting tight again, whilst doing so wiggle the barrel and it might pop out, if not give the screw a couple of turns as if to tighten and push on the end of the screwdriver and this should release it. The clip is obvious when the barrel is out !!
  4. paul_r
    paul_r Member
    172
    Maybe, there is quite a bit of tension on the part so it would need a good squidge (and holding in place for a day or two)
