List of cheap or free mods
ScottD3 Feb 16, 2012
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,122
  2. tdia4
    tdia4 TDIPOWARRR
    613
    De-badgeing. Just need hair dryer, some glue remover and some polish.
  3. TeKnodriver
    TeKnodriver Biodiesel Purrrr
    166
    new fuel filter - around £10 [my TDi wouldn't pull over 4k before changing!]
    replacing old rubber vacuum /N75 tubes - £2 or 3
    would say intake cleaning but 2 of the bolts refuse to budge on mine! grrr...
    err... tyre pressure check?..
  4. ldoshiv2
    ldoshiv2 Member
    82
    upgrade Registration lights to LED - £7.50 eBay
    Subtle tint your Rear lights - £9 tint + lacquor £3 best results warm ventilated room, patience and even coat
    white caps for dirty number plate screws !! 20pence !
    won some carbon fibre £15 ebay usually £25+ but keep eye on auction items, you may be lucky wrapped my grill ,not too sure about it though. took some time with heat gun. thoughts ? Pics are ppoor quality sorry was from phone
    [​IMG][​IMG]
  5. fARQUARE
    fARQUARE Member
    228
    S4 cloth interior - free
  6. Foxmeister
    Foxmeister Fired Up!
    1,785
    Centre console mod
    Roll of black vinyl from ebay £3.79 and some filler n sandpaper.
    Before
    During
    After
  7. Sulli79
    Sulli79 Active Member
    541
    37
    Ambient lighting for rear lights.
    Get ambient light unit out of a front light from a scrappy, drill two holes, have to strip down and glue ambient light unit internals in as there are no clips for the rear, then solder to these terminals.
  8. ScottD3
    15,161
    1,122
    Sun glasses holder from a Passat if you can find one for £10 or less.
  9. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,771
    31
    Vagcom adaptations such as setting anti-hijack, full closure alarm, etc.
  10. Nessy
    Nessy VW + Audi mad
    918
    84
    x 2
    Autolocking of doors above 15mph.
    Confirmatory horn beep on locking car via remote keyfob.
    1 press on remote to unlock drivers door/ 2 presses to unlock all doors.
    All free mods if you have the cable etc and all very worthwhile IMHO, in fact the best you can do for free............
  11. gmx
    gmx Member
    148
    Are there any DIYs for these?
    Horn beep would be useful since my flash on locl/unlock no worky :p
  12. Nessy
    Nessy VW + Audi mad
    918
    84
    Hope I don't get shouted at for posting a link from another site,lol....................
    AudiWorld Tech Articles
    It says A6, but it works perfectly on the A4.......
    Yes, its not totally free as you have to have the cable/software but I just used a cheapy Ebay copy lead (about £15 IIRC) and used the free limited-functionality version of VagCom to change my settings.
    Did this about 5 yrs ago now so a little hazy as to what exact code I changed it to, but I also managed to get a seatbelt warning light to flash up on the dash each time the car is started, although it is a tad useless,lol.
    I'd forgotten that window/sunroof close with the remote wasn't standard and was enabled doing this mod.....
    Definitely one of the best mods I've done to the car though, makes life with it so much more enjoyable.
  13. Bradderz_1988
    3,951
    235
    Ross-Tech is not responsible for any damage or problems that may result from following these instructions. They are to be used at your own risk.
    Specific Modules:
    01-Engine: -- KWP-1281
    VCDS works well with all engines available in the U.S. and most engines that users have tested in overseas markets.
    Idle Speed Adaptation:
    With engine warmed up, at idle:
    [Select]
    [01 engine]
    [Adaptation - 10]
    Enter channel 01
    Enter an adaptation value between 124 and 132
    [Save]
    (May require a Login of 01283 or 11463, depending on year or model)
    Throttle Body Adaptation:
    Turn the key on but do not start the car.
    [Select]
    [01 - Engine]
    [Measuring Blocks - 08]
    Enter Group 060 (may be Group 098 on some cable-throttle cars)
    [Go!]
    [Switch to basic settings]
    Once you do this you will see the top right display say ADP RUN. The TB
    adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in basic mode for about 30 seconds, then switch back to normal settings and you're all set.
    Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
    02-Auto Trans : -- KWP-1281
    VCDS works fine
    Recoding Tiptronic:
    In the newer cars, there are coding options for "Old" vs "New" "Tiptronic strategy". The "New" stategy (introduced in 2000 I think) is much more "automatic" than the old. To get the "Old Tiptronic strategy" where it won't downshift unless you come to a complete stop, I believe you have to change the coding in the following manner:
    [Select]
    [02 - Auto Trans]
    [Recode - 07]
    Enter the coding below
    [Do It!]
    Write down the original coding for future reference.
    Look at the fourth digit in the coding (Cylinders):
    0 or 1 - "New-style Tiptronic"
    2 - "Old-style Tiptronic"
    Look at the fifth digit in the coding (Market version):
    1 - "Rest of world, quattro"
    2 - "USA, quattro"
    3 - "Rest of world, FronTrak"
    4 - "USA, FronTrak"
    So, for a USA model A4 quattro, if the original coding is 00002, and you want to change to the "Old-style Tiptronic" strategy, change the coding to 00022.
    PS: As always, you play with stuff like this at your own risk. The "old" strategy is documented by VW only for "testing" and they explictly say that the car should be recoded the way it was before giving it back to the customer.
    03-ABS Brakes: -- KWP-1281
    VCDS works fine
    08-HVAC: -- KWP-1281
    VCDS works fine
    15-Airbags: -- KWP-1281
    VCDS works fine
    17-Instruments: -- KWP-1281
    VCDS Works fine.
    Immobilizer Procedures in the Ross-Tech Wiki
    Note: US/Canada model Audi A4/S4 do not have Immobilizers.
    Recode for warning lamps (through 1999 only):
    [Select]
    [17 - Instruments]
    [Recode - 07]
    Write down the existing coding for future reference.
    Enter 5-digit code from below
    [Do It!]
    Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
    00 - No available equipment
    +01 - Brakepad wear sensor warning active
    +02 - Seatbelt warning active
    +04 - Washer fluid level warning active (may only work with pre-2000 models)
    +16 - Navigation System (non-USA models)
    Look at the third digit in the coding (Market version):
    0 - "Germany" 24 hour clock
    1 - "Rest of World" 24 hour clock
    2 - "USA" 12 hour clock
    3 - "Canada" 12 hour clock
    4 - 4-cylinder
    6 - 6-cylinder
    Look at the fifth digit in the coding (Distance impulse multiplier):
    0 - TDI Engine (non-USA models)
    2 - Non-turbo Gasoline engine
    4 - Turbocharged engine
    So, if you want to have Seatbelt warning and washer fluid warning only in a 1999 Canadian A4 2.8, (add 00+02+04 = 06),3,6,2 = 06362.
    A complete instrument cluster coding chart which includes 2000 and newer cars is available in the Ross-Tech Wiki.
    Change Language Displayed:
    [Select]
    [17 - Instruments]
    [Adaptation - 10]
    Enter channel 04
    The available languages are :
    00001 - German
    00002 - English
    00003 - French
    00004 - Italian
    00005 - Spanish
    00006 - Portuguese
    [Save]
    Resetting Service Reminder Intervals:
    http://www.ross-tech.com/vag-com/cars/audi_sri.html
    22-AWD – Purely Mechanical!
    The quattro system in these cars is purely mechanical, no electronics at all. This address is used by the Haldex system used in transverse-engine cars like the TT, the A3, and various Golf/Bora models.
    35-Central Locks: -- KWP-1281
    VCDS Works fine (note: pre-'97 A4's may not have this module).
    Recode locking options
    [Select]
    [35 - Cent. Locks]
    [Recode - 07]
    [Do It!]
    A4 pre-1998 with Delta radio and anti-theft system
    Standard Coding: 03468
    A4 pre-1998 with Delta radio, anti-theft system and keyless entry
    Standard Coding: 12172
    A4 1998+ with Concert/Symphony radio and anti-theft system
    Standard Coding: 03340
    S4, A4 1998+ with Concert/Symphony radio, anti-theft system and keyless entry
    Standard Coding: 16140
    Add the following options to your coding number:
    +64 Windows up, sunroof close, and windows down with remote.
    -04 One touch unlock of all 4 doors and trunk
    -1024 Remove horn honk when arming
    +32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed)
    So, if you want to have a 1999 A4 with Concert radio and anti-theft system and keyless entry, and you want to add window control with the remote along with auto-lock, then:
    add 03340+64+32= 03436
    37-Navigation: -- KWP-1281
    VCDS Works fine.
    45-Int. Monitor: -- KWP-1281
    VCDS Works fine (note: This is tied in with 35-Central Locking so it may not work with pre-'97).
    Sensitivity Adjustment
    [Select]
    [45 - Int. Monitor]
    [Adaptation - 10]
    Enter channel 01
    Enter a value between 50-100 (it should be 100 by default) for the sensitivity of the ultra-sound sensors
    [Save]
    55-Headlight Range: KWP-1281
    VCDS Seems to work fine.
    Note this controller is only present on cars with Xenon headlights.
    56- Radio: – KWP-1281
    Please read the following pages pertaining to Audi Concert and Symphony Radios.
    I found this really usefull and have kept it in my notes lol the misses hates auto locks especially when it's raining and I forget the doors are locked lol
  14. Oranoco
    Oranoco Well-Known Member
    3,918
    392
    N75 mod. Remove N75 valve and turn screw in top 1/2 turn anti clockwise. Brings the boost in more aggressively
  15. Foxmeister
    1,785
    Pre-facelift bumper to look facelift
    Again, just some black or carbon vinyl needed.
    Before
    Remove the bumper grilles and apply vinyl to uprights between grilles to look facelift style
    After
    Andyb5tdi likes this.
  16. ScottD3
    15,161
    1,122
    Thanks lads.
    Got some ideas as well. :)
    Keep them coming.
  17. amicallef1991
    amicallef1991 Member
    61
    Anyone know if the Vagcom adaptations above like
    would work on an audi a3 8l 2002?
  18. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    165
  19. chale989
    chale989 Member
    79
  20. ScottD3
    15,161
    1,122
    Not on ours.
    Cars over 2002 started having EGR sensors and that would throw up an error but us oldens are ok.
  21. michaelg1001
    michaelg1001 Active Member
    205
    30
    Drill some holes in the bottom half of your airbox for massive induction noise :lmfao:
  22. Nessy
    Nessy VW + Audi mad
    918
    84
    It does affect emissions, in so far as no more ruddy smokescreen behind you whenever you give it some welly!
    I only did this mod about a week ago, haven't actually removed any of the EGR pipes etc , instead fitted a relatively thin stainless plate (1.2mm thick) being sold as a blanking plate, so using mine as a solid gasket really!
    Has the same effect as using one of those thick blanking plates (loads of them are 3-4mm thick on Ebay) but engine bay looks totally stock.
    My car has a tuning box and had always assumed the smoke on heavy acceleration was caused by that; nope!
    I now can't get it to smoke, wish I'd done it years ago, and low-down pickup has been transformed.
    The best car-related £3 I have ever spent.
    And definitely no warning lights evident either.
  23. amicallef1991
    61
    Anyone:
  24. ScottD3
    15,161
    1,122
    Can't see why not.
    Look in the central locking section.
  25. AR-rkon
    1,913
    165
    Yep, VCDS will do that...
  26. Oranoco
    3,918
    392
    Can I add indicator flash on locking with VCDS lite, if so how do i do it as I want to fiddle.
  27. Nessy
    Nessy VW + Audi mad
    918
    84
    A4 Coding the Control Module
    Article By: John Stahmann - 2000
    It's been so long since I recoded my car (7 yrs) that I really cant remember what it had as standard?
    I think though that it came with indicator flash on locking from the factory and that I added the horn beep as it was all too easy to miss the lights flash when locking and I was forever going back to the car to check it was actually locked? lol
    The more I think about it, the more I'm sure that this is the case.....
    EDIT
    If you look at that article, all of the coding settings list *lights flash when arming , so it doesn't appear to be addable or removeable.
    On that basis, I'd say your car should already have it, supposing it has factory flip-key remote locking?
    If it doesn't flash when arming try one of those codes, just make a record of your old code in case you need tio revert back to it!
  28. Oranoco
    3,918
    392
    Thanks, will try. Despite the lights mine is actually a '96-97 car though so no flip key.
  29. aragorn
    18,306
    806
    The early cars with the 4A0 pump dont respond to vagcom afaik, its essentially a "dumb" box.
    It should go "boop" though when you lock it?
    If it doesnt go "boop" either the horns disconnected, or its a later 8L/8D pump, which should flash the indicators by default...
  30. Oranoco
    3,918
    392
    It does go boop when I lock it, was hoping to stop that too. Are the pumps interchangable?
  31. Oranoco
    3,918
    392
    Well had a play with VCDS Lite 1.2 and changed the settings on the central locking no problem. Have added the hazzard flash on locking and removed the horn hoot, but may put that back, even added the anti hijack :)
    Downside is I can't seem to reset my IN1 indicator as it says my software isn't licenced :(
    Any idea how I get round this as I don't want to pay $99 for that privilidge?
  32. Sulli79
    541
    37
    Got a replacement set of buttons for my key, only £2 on eBay. Not genuine obviously but to be fair seem ok(for now at least)
    centre key has new buttons, left is the genuine set and right is the old buttons image.jpg
    ScottD3 likes this.
  33. AlexA4Avant
    AlexA4Avant Active Member
    633
    105
    43
    I have done number plate. Led conversion. £2.50 for 5 so did glove box and interior light. One time of high gloss plastikote paint and done fog light grills and bonnet.grill about 8 pound. Ring ultima +120% h7 bulbs at 12.50 I no over.budget but well worth it. Does make it a massive difference front side lights 2.99 I think brought.from another car
  34. captn_0bv10us
    captn_0bv10us New Member
    i have done a few cheap\ free mods ones i seen other places and one i came up with on my own ill include pix later on all my mods...my car is a 2000 a4 b5 quattro facelift with an atw engine.. ill answer any questions you may have if i can before all mods my k03 had a peak boost of 7-8 psi fyi..
    first off some of these are cheap while others are free like my original mod that is a bit hairy and do at your own risk if you dont feel comfortable doing it i suggest you dont cause you can screw up your turbo pretty bad
    1) swapping out the stock are box for two cone filters (KEEP OLD AIRBOX FOR SMOG PURPOSES UNLESS YOU BUY K&N)
    2) vent pod boost gauge, (ITS A MUST HAVE FOR ALL BOOSTED CARS)
    3) blacking out all chrome except for badges including blacking out wheels except for audi symbol
    4) blinking halos around xenons if you have xenons
    5) vacuum delete
    6) re-circulation valve swap
    the last 2 are not for the faint of heart and can potentially cause some damage if you do something wrong
    7) spring mod (this is where you attach a small spring to a waste gate that no longer can hold the original pressure ie old and worn dont over due it youll be sorry)get it back to the 7-8 psi it was originaly at)mine would only hit 2 psi before it would open thats why i did the spring mod
    8)last but not least i wont go into details here but if you want to know how i get 12-15 psi with a stock k03 and no chip pm me and ill tell you
  35. Andyb5tdi
    Andyb5tdi B5 1.9TDi AFN Audi A4 saloon
    116
    23
    Looks good, what grill is that?
  36. mikeyorion
    mikeyorion Member
    80
    Rs4 replica grill ?
