limp mode please help
dave500 Sep 11, 2012
  1. dave500
    dave500 New Member
    hi folks, new to this forum so please forgive me if i am going over old ground.
    my wife was driving her 2.0tdi 06 plate on sunday when the glow plug light started to flash, she pulled over and rang me ( over 100 miles away ) i told her to carry on home and would look at it in the morning. She rang back to say the car was very sluggish and would not rev over 3000rpm. Any way she got home safe and sound.
    In the morning i stared the car, no glow plug light but still wont rev over 3000, took it to a local independant and he said the turbo was knackered as it was hardly turning. Is this stuck vains and can be cleaned or do i need to give him £1150.00 of my hard earned.
    Any help would be great. Dave
  2. simon.m
    simon.m Active Member
    2,747
    id not be giving £1150 to any one for a turbo **** thats a lot try these guys if you do need a new one priced mine at £335+vat but id looking to cleaning it first
    Prestige Engine Products Limited
    UNIT 7, Hanbury Wharf
    Hanbury Road
    Droitwich
    Worcs.
    WR9 7DU
    01905 792211 'phone
  3. dave500
    dave500 New Member
    Thanks Simon I will ring them in the morning, any idea if sticking vains will stop it from reving ?
  4. pauldazzle
    pauldazzle Well-Known Member
    1,193
    95
    Get it scanned for fault codes before you throw any money at it. A dodgy MAF sensor will put the glow plug light on & kill the performance.
  5. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,064
    71
    Does the DPF cause the glow-plug light to flash or does it have it's own warning light?
  6. dave500
    dave500 New Member
    sorry jj not sure what you mean by DPF. The light is not on at the moment but it still wont rev. someone said if you disconnect the battery it will reset the ecu, is this right?
  7. pauldazzle
    1,193
    95
    DPF = Deisel Particulate Filter.
    Failed MAF will do what you describe, but get the car scanned as it's guess work until you do that.
  8. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,554
    896
    You havent said if its a 140 or 170 TDI because if its a PD140 then they dont have a DPF as your car is a 06 plate. I believe the DPF's were introduced when the CR versions came out........can someone clarify this please. As said before get a scan done of the car and then take it from there.
  9. Cribbon
    Cribbon Member
    152
    unplug the maf sensor and see if it will rev over 3000rpm, this would give u an idea if it is maf sensor!
  10. astradti16v
    astradti16v Member
    54
    Are you sure it hasnt got into limp mode due to the DPF being close to full? I would get it plugged into a diagnostic machine to check that first before spending hundreds/ thousands!
  11. pauldazzle
    1,193
    95
    Works on petrol VAG cars, & some deisels, but to my knowledge will put Audi TDI's in to limp. Does on mine for sure.
