limp mode intake manifold pressure exceeded intermittant
rock ape Sep 20, 2012
  1. rock ape
    rock ape New Member
    Hi I recently brought a 2003 A4 convertible 2.5TDI and have a limp mode problem so far maf and map sensors changed plus valve on bulkhead (dont know what its called) mr muscle to the turbo twice particulte filter cleaner put through the system and cat cleaner every one of these items have made improvements but I seem to be skirting around the fault (0575) running out of ideas can anyone help
  2. swarcup
    swarcup Well-Known Member
    1,326
    40
    hi there
    this is he ross tech wiki for that fault code 00575 - Ross-Tech Wiki
    you have already done the n75 valve by the sound of it (the bulkhead one) have you checked all of the hoses?
  3. rock ape
    rock ape New Member
    rgr that changed that I am wondering if improvement after Mr muscle used are not from turbo but has had a slight cleaning effect on either cat or particulte filter ??
  4. rock ape
    rock ape New Member
    by the way other causes of 0575 can be blocked particulate filter/ blocked cat its a shame vagcom seems to be such a basic diagnostic system very basic and cannot properly fault find and as I found out to my cost with BMW main dealership for my Z3 they have "technitions" not mechanics if the plugged in diagnostics does not lead them to the fault by the hand they are clueless.(rant over)lol
  5. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    I had this on the wifes Mk5 Golf. It was the joint cracked of the exhaust gas sensor to the manifold. Couple of tack welds and sealed it up and has been fine ever since.
  6. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    This pops up on mine whenever I scan, I put it down to the re-map I have on the car - im guessing the turbo is giving more pressure so its outside standard tolerances and throwing up a code?
  7. rock ape
    rock ape New Member
    Hi today I gave it the full Basil Faulty gave it a dam good thrashing major improvement thinking this has blown some of the build up in the cat/particulate filter after the additives have been through the system will retreat with cleaner and Basil it again I will report outcome in a few days Rock
  8. rock ape
    rock ape New Member
    Hi well so far so good took the Audi out for a run (pi##### with rain the problem seems to be cured hopefully.
