Lil bit of advice needed from the 8p lads for my 2.0 tfsi 8l conversion
AARON77 Feb 1, 2012
  1. AARON77
    AARON77 Well-Known Member
    1,322
    26
    I'm doing a 2.0 tfsi conversion on my s3 8l
    The spec is gonna look a lil like this
    Ie rods and pistons with a nos spec crown
    Gtx3071
    Think? Apr mani down pipe
    Rs4 injectors
    Rs4 FRV
    Qpeng stand alone management
    S3 8p ecu
    Stage 3 revo
    just have a few questions
    What is your 2.0 tfsi fuel pump good for
    What dv to you guys use
    Does anybody use an alloy inlet mani
    What would be a good induction/ filter setup in my situation
    I'm open to all advice/information that any of you guys can offer
    I'm totally new to this engine so pls excuse my ignorance
  2. AARON77
    1,322
    26
    Come on lads there must be one or two of you with a modified S3 !!!!!
  3. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    Warren-S3 is having a lot of work done I think.
    Ping him a pm towards here.
  4. s3ollie
    s3ollie Member
    762
    What is your 2.0 tfsi fuel pump good for - About 320-330bhp if that, you will defo need an uprated pump or internals on stage 3
    What dv to you guys use - Forge DV here. dont know of many other choises.
    Does anybody use an alloy inlet mani - Cant comment on this
    What would be a good induction/ filter setup in my situation - I have the ITG and people with big power are running these. There is also the forge twin take and evmos to name a few.
    what sort of power are you expecting?
  5. moag
    moag she's no d-turbo
    821
    35
    PM boydie. He's running around 350bhp or so at stage 2+
  6. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,216
    305
    there is a few chaps on here with modded tfsi's , boydie and jungleman have got nicely modded s3's
  7. AARON77
    1,322
    26
    450 bhp
  8. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,481
    What is your 2.0 tfsi fuel pump good for (Unmodified about 310bhp, HPFP takes this to about 450bhp)
    What dv to you guys use (OEM Revision D, I find it's more responsive than other brands)
    Does anybody use an alloy inlet mani (No, less heat transfer in plastic manifold, no need for phenolic gaskets etc.)
    What would be a good induction/ filter setup in my situation (ITG Maxogen CAI)
    Not sure that RS4 injectors have best spray pattern for the 2.0T, S3 injectors good for 400bhp with pattern/flow
  9. AARON77
    1,322
    26
    It's mainly the inlet I'm really wanting
    So I can have good strong place to mount my nos jet
    Should run 450 bhp
    With another 50 shot of nos to eliminate lag
