Lights under door handles?
Mikemc Feb 28, 2013
  1. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    Any body done this mod?
    I'm intrested in doing it since I had a BMW with then on and thought it was a good idea and looked cool.
    Would it be a case of drill a hole under each handle silicone an led in and wire it up to the interior bulbs so when you open car they come on?
  2. plymouthaudi
    plymouthaudi Member
    88
    Nice idea would be interested if anyone has done this too?
  3. A3Kent
    A3Kent Well-Known Member
    1,571
    249
    Not sure, but I noticed quite a while ago someone selling the complete door handle which already had the light fitted so maybe it's better/easier to buy new handles (although probably more expensive)
  4. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    606
    34
    Could you not just buy the sticky led strips, cut them down to size and possibly thread the wire through the door handle instead of drilling holes?
  5. Mikemc
    1,024
    37
    But where would you thread the wire if you haven't drilled a hole for it to go through?
  6. chris.vincent3
    606
    34
    I'm sure the door handles arnt an air tight unit, there must be a big enough gap where the handle is held on the surround that oes through into the door to operate the mechanism in the door.
  7. Mikemc
    1,024
    37
    Ill have a look tonight when I get back from work, what's it like threading a wire through the door into the footwell area?
  8. Ash187
    7,520
    758
    you wouldnt need to take it to the footwell... wire it into the puddle lights under the door :idea:
  9. Mikemc
    1,024
    37
    I've thought about that but thought they only come on when the door is opened?
  10. Ash187
    7,520
    758
    hmmm you may be right there... well what about the ambient lights on the inside door handle? they light up when the car lights come on! thats where i have tapped on my illuminated Bose grills and they work perfectly
  11. Mikemc
    1,024
    37
    Sounds good, I take it I just take a wire off for live and earth and tap onto those?
  12. Mikemc
    1,024
    37
    Just checked and my inside door handles don't light up in the car when I press the unlock button
  13. Ash187
    7,520
    758
    ahhh yes I also have retrofitted the auto lights to mine so I get the coming home lights which lights up everything when I unlock the car or get out of the car, you would ideally want coming home to make sure that the light comes on when the car is unlocked
  14. Mikemc
    1,024
    37
    What's the estimate price on that mod?
    Riccoshire likes this.
  15. Ash187
    7,520
    758
    The full auto lights install is around £500, but you can do the coming home/leaving home hack so that the lights come on when you unlock the car... Only thing is that they will come on in the daytime too as there isn't a light sensor fitted to tell it when it's dark
  16. mjr901
    mjr901 Guest
    Sorry to sneak in here, Can this hack be achieved with the with lets say my 2012 S3 8P3 yet? I heard it wasnt do-able because of this that and the other after about 09 plate?
  17. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    I have the Coming/Leaving home mod done on my 09 plate without a problem.
    As Ash says, they do come on during the day due to the lack of a light sensor.
  18. JS3
    JS3 Member VCDS Map User
    227
    Just had the full LED interior light install by jb00 on here (JMB Retrofits). Good kits, looks good and a great install. The lights under the handles are on when the side lights are on, and the footwell lights can be programmed to be adjusted brightness from 0% (off) to 100% fully on whilst the side lights are on. The lights under the handles arent as bright as what I thought they would be but it finishes off the interior light mod nicely. It needs a new handle. This was installed on a 2010 S3.
  19. Ash187
    7,520
    758
    Not yet found a solution for the coming home hack on the newer cars, the auto lights install is the only way for the moment
    the light under the door handle that the op wants is for the outer (exterior) door handle. Not the interior one that comes with the lighting pack
    though the interior ones do look sweet
  20. mjr901
    mjr901 Guest
    Ah, Balls. :keule:
  21. JS3
    227
    Ah ok....my bad!
  22. elrao
    elrao Member
    379
    Any more info on the full auto lights retrofit? So used to having it on all my other cars!
  23. WALTO TDI
    WALTO TDI Member
    293
    12
    What's the hack and where can I get it?
    cheers
  24. s3facelift09
    s3facelift09 Member
    244
    23
    Does anyone have a part number for the inside OEM led door handles??
  25. TDI140
    TDI140 Well-Known Member
    1,632
    175
    Wiring would have to be done to the home coming lights through door card and into the dash sounds like a long hard time consuming mod but would love to see someone carry it out with instructions
  26. Mikemc
    1,024
    37
    I might have to give it a bash, anybody recommend me some LEDs to sit under the handle?
