Lights left on, Warning sound?
ajax1976 Jan 20, 2013
  1. ajax1976
    ajax1976 Well-Known Member
    1,279
    656
    Just checking if my car should have an audible warning if I open the door with the lights left on?
  2. NHN
    29,510
    1,764
    Usually they do yes, but if its got coming/leaving home it doesnt if set to auto, but we're referring to headlights yes?
  3. ajax1976
    1,279
    656
    I don't have auto lights, just normal plain old switch. As previous cars I expected to have a warning if I'd left the switch in any position but off with the ignition off and opening a door. I get nothing at the moment so basically no warning if I've left the lights on, strange!!
  4. kite
    kite Member VCDS Map User
    677
    Have you removed the key ?
    If your not getting a beep with the key out/door open/lights on, could have a problem with the door lock.
    Does the DIS show the door open graphic?
  5. ajax1976
    1,279
    656
    Yes, key removed and no sound when opening the door. I could if I wasn't paying attention leave the lights on and lock up and come back to a flat battery with no warnings.
    With the ignition on the DIS works fine, all door open warnings work perfect.
  6. NHN
    29,510
    1,764
    I reckon its still related to the door as Kite said, sorry didnt think of that as just driven 5 hours home in snow & was up at 7ish, so bit tired.
  7. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    I have exactly the same problem on mine, DIS door graphic is working fine. Would be nice to get a solution.
  8. ajax1976
    1,279
    656
    Doesn't bother me too much now I'm aware of it, once the weathers better I'll look into it. Its maybe a Fife thing Greeny, I'm in Kennoway not far from you in Leuchars
  9. kite
    677
    Scan for faults.
    You might be able to test the buzzer with VCDS output tests.
