Lightened underdrive pulleys. Are they really worth the money....?
Markb Dec 13, 2005
  1. Markb
    Markb Active Member
    2,139
    As subject are these Lightened underdrive pulleys really worth the money? Do they offer any gains over the standard items?
    Just asking as I'll need my cam belt doing in a few thousand. So I was thinking about having these fitted while I was at it.
    Cheers Mark.
  2. HTC
    HTC Active Member
    3,428
    9
    Lightended pulleys don't have the harmonic balancer, so you run the risk of hurting your engine via vibration. Lots of discussion about the subject on vwvortex.
    The underdrive can cause charging issues at lower revs and also you may find your A/C doesn't pump round as fast as it should. Not a huge problem most of the time, but if you spend time in traffic, then I'd steer clear.
    Personally I would fit them if you paid me for the tiny amount of power they supposidly give.
    They do look bling tho!
  3. Markb
    Markb Active Member
    2,139
    Cool cheers for the advice I think I will steer clear then!
  4. amb276s3
    amb276s3 bird spotter
    292
    I fitted the neuspeed pulleys, but only because i have a lightweight flywheel, seemed to help the balance, no noticable power gains but am due a r/r test so i will letyou know.
  5. simonelman
    simonelman Member
    78
    Hi
    I have lightened pulleys fitted for about 3 years now and no problems.
    Your right you dont gain power but release it. The car will run smoother and revs faster
    Simple to fit Just do it.
    Simon
    MRCtuning-remaped in real time
  6. Ryanc
    Ryanc Active Member
    1,321
    Hows it running simon?
  7. simonelman
    simonelman Member
    78
    Hi Ryan
    Runing fine
    The cars just been re-maped by the guys from MCRtuning an early Christmas present.
    Now the car performs very well no lag pulls hard to the re line.
    Its been maped with more power and less boost which cant be bad.
    The way MCRtuning work is that they are able to re-map on the fly.Its maped on the actual road not a rolling road Mihnea sits with his laptop and its something out of the Matrix with thousands of numbers tumbling before him.He knows his stuff.
    We need a rolling road day
    Simon
  8. Ryanc
    Ryanc Active Member
    1,321
    I'm going to awesome on the 29th,some of the other big boys will be there pushing 400+,come along.
  9. dummi
    dummi smoking a6
    1,210
    i was considering the ECS pulley kit with rs4 flywheel, the flywheel is still heavy but i can't live daily with the single mass
    as you say the pulleys look like they have no harmonic balancer? and are just very low fat pulleys, not underdrive. the alternator and power steering pulleys are much smaller, is it short term or long term effects on the engine you speak of? maybe worth experimenting with just ECS light alternator and powersteering and leaving crank stock with harmonic balancer? in place?
