Light scratches on the painwork - any recommendations?
Cootie May 15, 2008
  1. Cootie
    Cootie Member
    80
    I think some little **** has decided to redecorate my bonnet. :gun2: The scratches aren't deep though and seem slightly superficial, as if someone has got a stone and rubbed it across the surface or you'd got grit in your sponge when cleaning it. Can't have been that though due to when it happened.
    Anyway, can anyone offer any recommendations for sorting it? Would T-cut or similar do the job or am I looking at getting someone to buff them out.
    Cheers for any help!
  2. davemk
    davemk Active Member
    463
    37
    ScratchX by Meguiars is supposed to be good for light scratches. T-cut seems to be frowned upon nowadays.
    *Edit* - just reading that back, it makes me sound ancient. I'd just like to clarify that I'm not! :yahoo:
  3. matzxr
    matzxr Member
    47
    Scratch X as Dave suggested is ok on very light scratches
  4. jamiekip
    jamiekip Guest
    Maybe approach one of the professional detailers and ask for just a bonnett correction?
    Reckon it would be a coulpe of hours work tops - so maybe £100 to correct?????
    Unless there is someone on here prepared to let you loose with their own porter cable???
  5. G10 works for me!
  6. Kev_M5KPL
    Kev_M5KPL Member
    269
    G3 is ment to be a good one but i would use Meguiers scratch X . or as Jamiekip said take it to a professional
  7. steve184
    steve184 Active Member
    1,138
    for scratches i use 3000 grit wet and dry - lightly rub while very wet then polish up with scratchX does the trick but be very careful not to go to far or you will ruin the panel altogether - this is also a good remedy for bird muck etchings
  8. d3fy
    d3fy Active Member
    1,412
    Poorboys SSR1 is good stuff
  9. Cootie
    Cootie Member
    80
    Thanks a lot guys - think I'll give some ScratchX a go to start with and see if that does the trick. Cheers!
