Light problems after attempting Coming home light hack...Please help
welshwoody Jan 20, 2012
  1. welshwoody
    welshwoody Member VCDS Map User
    436
    10
    Hi, I know theres a fair few threads on here about coming home lights showing what needs to be done and what problems people have had but I dont seem to be able to find mine on there.
    Basically this is what happened. I have my neighbours laptop with full VCDS on it so I thought as I have it until Sunday Id do this little upgrad as it sounds like a usefull feature.
    Anyway I followed the guide and usind a repair wire I connected one endt to pin 12 in block E and the other end I earthed to the bolt as shown in the guide. I had it conected to the block and then secured the earth point before reconnecting block E.
    I then activted the coming home feature through VCDS via module 09, central electrics and checked bit 5 and 7 and saved the changed with the "Done, Do it" button.
    I got out of the car and locked it, the lights stayed on for 30 seconds then went off and the same goes for unlocking. Perfect I thought...
    However when I have the light switch in DRL mode I have the dipped headlights on, when I put the lights to dipped I have only DRL but all the amnient lighting comes on in the car as well as the dash lights and main beam is as it used to be, so basically the dipped and DRL seemto have been switched around somehow.
    I thought Id remove the cable from pin 12 so I removed it from the earthing point and covered the end with electrical tape whilst I look into things. I used VCDS and unchecked the boxes and saved it again so its all back to as it was before I began.
    Now the coming home feature is still active as it was and the light switch is still all mixed up as in the DRL and dipped settings are switched?
    How is this possible? Ive put everything back as it was, ideally Id like to have the coming home feature but more so than that Id ike to have a light switch that works properly!
    Any help is greatly appreciated.
    I forgot to add that I have already got the advanced comfort setting active through chanel 17 bit 82...
    Chris
  2. welshwoody
    436
    10
    Looks like Im gonna have to take it in to Audi to have a look, Ive completely removed that wire and the coding is all back to how it was before but its F**ked...
  3. Avus Sportback
    Avus Sportback Member
    Try only checking bit 7 and not 5, I had similar probs to you when I'd did it.
    Do you have the LED's and Xenons?
    If not I believe that you only need to touch the wire to earth which the activates the CHL's in the ECU, when you initially connected the wire to earth you activated it, removing the wire won't do anything, try dabbing the wire back to the earth again and see if it turns off.
  4. welshwoody
    436
    10
    Hi, I dont have Xenons or LEDs, I tried to touch the earthing point again ut it still the same. I tried just checking bit 7 too butthat gave me the same problem. Its odd because when I hook the laptop up to it its all showing as being unchecked, no option for coming home, leaving home have been selected at all. Maybe Ill go and scan the car for faults and post the log up....
  5. welshwoody
    436
    10
    OK hopefully someone might be able to help from seeing this log...I know the one fault on the boot light is because the bulb needs replacing...
    Saturday,21,January,2012,18:41:53:10074
    VCDS Version: Release 10.6.4
    Data version: 20110418
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 77
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: None
    Part No SW: 03G 906 021 TP HW: 03G 906 021 AN
    Component: R4 1,9L EDC 000SG 2595
    Revision: --H09--- Serial number: AUX7Z0H9FN60G6
    Coding: 0000071
    Shop #: WSC 06314 000 00000
    VCID: 800B0433AA93
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 13422012092700FDC81304E4901D00813800
    VCID: 74E3D8E36E2B
    Address 08: Auto HVAC Labels: None
    Part No: 8P0 820 047 B
    Component: J255 Klima Man H07 0030
    Shop #: WSC 00000 000 00000
    VCID: 2F69178FC78D
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
    Component: Bordnetz-SG H54 2801
    Revision: 00H54000 Serial number: 00000008984701
    Coding: 0DA82F81B0141380EF00001C0000000000084E1564010403002800000000
    Shop #: WSC 06314 000 08192
    VCID: 489B5C134223
    Part No: 8P2 955 119 F
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 06314
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003000000000
    Coding: 303142383038303030374A55305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 499D59175929
    Driver's Airbag Crash Sensor:
    Serial number: 3572DRB400008059011A
    Passenger Side Airbag Crash Sensor:
    Serial number: 3582DRB400008058710G
    Driver's Rear Airbag Crash Sensor:
    Serial number: 35128RB4000044A0A249
    Passenger's Rear Airbag Crash Sensor:
    Serial number: 35228RB4000044B38017
    Driver's Front Airbag Crash Sensor:
    Serial number: 35547RB40000464977FW
    Passenger's Front Airbag Crash Sensor:
    Serial number: 35647RB400004649750G
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0004012
    VCID: 418D41376119
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
    Component: KOMBIINSTR. VDO H18 0830
    Revision: D0H18006 Serial number: 2249H006007530
    Coding: 0004428
    Shop #: WSC 00011 888 96745
    VCID: 397D29D709C9
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H16 0202
    Revision: H16 Serial number: 2700K0893003FA
    Coding: E9807F064006022103
    VCID: 356525E725D1
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H18006 Serial number: AUX7Z0H9FN60G6
    VCID: 397D29D709C9
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 Q HW: 8P0 035 192 Q
    Component: RNS-E HIGH EU H76 0660
    Revision: 05S Serial number: AUZBZ7J0907106
    Coding: 0205715
    VCID: 3D753DC71DE1
    1 Fault Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 51
    Mileage: 120283 km
    Time Indication: 0
    Date: 2011.06.14
    Time: 18:54:23
    Freeze Frame:
    Mileage:
    Count: 1406
    Clock: 18:54
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
    Component: Tuer-SG H03 0060
    Coding: 0000692
    VCID: 43814B3F7B05
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 232 2301
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2A5F069BFC6F
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1980200002586D0985054C9FC637
    VCID: 43814B3F7B05
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    1 Fault Found:
    01565 - Luggage Compartment Light (W3)
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Coding: 0000692
    VCID: 448348237E0B
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205715
    VCID: 3D753DC71DE1
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 51
    Mileage: 120283 km
    Time Indication: 0
    Date: 2011.06.14
    Time: 18:54:23
    Freeze Frame:
    Mileage: 120280 km
    Count: 1406
    Clock: 18:54
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
    Component: Tuer-SG H04 0040
    Coding: 0000144
    Shop #: WSC 06314 000 1012544
    VCID: 418D41376119
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
    Coding: 0000144
    VCID: 428F4E3B641F
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 335 HW: 8P1 862 335
    Component: FSE_256x BT H41 0650
    Revision: 00000000 Serial number: 00000005259217
    Coding: 0011422
    Shop #: WSC 98111 611 11111
    VCID: F4E358E3EE2B
    End ---------------------------------------------------------------------
    Saturday,21,January,2012,18:47:39:10074
    Chassis Type: 1K0
    Coding: 0000071
    VCID: 800B0433AA93
    Revision: 00H35001
    VCID: 74E3D8E36E2B
    VCID: 2F69178FC78D
    VCID: 489B5C134223
    Coding: 00056595
    Shop #: WSC 06314
    VCID: 499D59175929
    Coding: 0004012
    VCID: 418D41376119
    Coding: 0004428
    VCID: 397D29D709C9
    VCID: 356525E725D1
    VCID: 397D29D709C9
    Coding: 0205715
    VCID: 3D753DC71DE1
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 51
    Mileage: 120283 km
    Time Indication: 0
    Date: 2011.06.14
    Time: 18:54:23
    Freeze Frame:
    Mileage:
    Count: 1406
    Clock: 18:54
    Coding: 0000692
    VCID: 43814B3F7B05
    Revision: 00H15000
    VCID: 2A5F069BFC6F
    VCID: 43814B3F7B05
    1 Fault Found:
    Coding: 0000692
    VCID: 448348237E0B
    Coding: 0205715
    VCID: 3D753DC71DE1
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 51
    Mileage:
    Time Indication: 0
    Date: 2011.06.14
    Time: 18:54:23
    Freeze Frame:
    Mileage: 120280 km
    Count: 1406
    Clock: 18:54
    Coding: 0000144
    VCID: 418D41376119
    Coding: 0000144
    VCID: 428F4E3B641F
    Coding: 0011422
    VCID: F4E358E3EE2B
  6. Avus Sportback
    All is normal there, I assume you have done an RNS-E retrofit hence the (37) navigation and (56) Radio Antenna faults.
  7. welshwoody
    436
    10
    Yeah I retrofitted the RNS-E myself...so its nothing coding related then?
  8. Ash187
    7,443
    704
    have you tried to deactivate it in your dis? as you have the advanced comfort turned on it sounds like it is still active there. use the wiper stalk to go through the menus and switch it off from there and then test
  9. welshwoody
    436
    10
    Thats the other problem, it never showed up in the DIS at all, when I installed the footwell lights from RobinA3 and activated them, they show up in the DIS under the lights menu but the coming home lights never showed up on there at all. Im going to go and try connecting that witr back to pin 12, then connect a seperate wire to the eathing point. Sit in the car and lock it,then unlock it, the lights should come on then touch the two cables to see if that stops it. Its the only thing I can think of trying...
  10. welshwoody
    436
    10
    Nope that didnt work,I touched the cables and it didnt do anything whatsoever, do you think if I dissconected the battery for a while it might do something? Im running out of ideas? Even thinking should I be thinking about re wiring the connection on the back of the light switch so the DRL and headlights are the other way around. Knowing my luck though Id somehow blow the car up. How can something so simple have gone so so wrong?
  11. welshwoody
    436
    10
    Well disconnecting the battery for an hour did nothing, guess Ill have to take it to Audi...
  12. welshwoody
    436
    10
    The award for worlds biggest idiot goes to...me! Just thought Id update this, I took the car to Audi as I said I was going to. They booked the car in for an hour which should have been £114 and after a few hours they called me to tell me the news. They said there was absoloutly nothing wrong with my car, it had them stumped for a while as nobody (suprise suprise) had ever taken a car in with this problem. After trying to fix it for a while they decided to simply check with one of the new A3`s they had there and low and behold it was exactly the same. So on the plus side they didnt initially realise the DRLs are brighter than side lights, just like I didnt. On the plus side I had the car washed and waxed and a free health check and was only charged £28.
    I felt a complete and utter fool but Im glad that Audi didnt charg the full whack, plus by me taking my car in to them they learnt something too, lol.
    So basically the car was fine all along and the coming home/ leaving home lights work perfectly, the hack had worked all along.
    Lesson learnt.
  13. Ash187
    7,443
    704
    sorry im lost? you had first said the problem was that the sidelights switch would light up the DRLs and vice versa... so now your saying that the light switch was not messing around but in fact you just didnt know that the sidelights are more dim than the drls?
  14. welshwoody
    436
    10
    No this is what I put in the first post...
    "However when I have the light switch in DRL mode I have the dipped headlights on, when I put the lights to dipped I have only DRL but all the amnient lighting comes on in the car as well as the dash lights and main beam is as it used to be, so basically the dipped and DRL seemto have been switched around somehow.
    Any help is greatly appreciated."
    So basically the issue ws that I never noticed, or knew the DRL`s were brighter than the side lights.
  15. Ash187
    7,443
    704
    yes we are saying the same thing!
    :asskicking:
  16. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,662
    116
    Haha. Classic.
  17. Helifella
    Helifella Co-Driver ~ Hattie Staff Member Moderator Regional Rep VCDS Map User
    569
    149
    43
    Confused dot com.
  18. welshwoody
    436
    10
    Doh! yeah were both saying the same thing....
