light buld fault
tdi-man Jul 26, 2012
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    nearly ever morning i get a light bulb out fault but i have no bulbs out
    once i put my lights on fault goes
    any ideas ?
    thanks
  2. a3glenn
    a3glenn 6th gear
    99
    do you have auto lights? i have the same sort of problem, if i leave my lights on or leave it switched to auto lights, then when
    i start my engine it tells me that both indicators are out, i then indicate both ways and the fault clears,
    if i start my engine first then switch on the light (not leaving the auto switch on) i have no problems
    i have had this fault for 4 years lol, the only thing i can think is the auto sensor behind the centre rear view mirror but never got around to looking at it.
    let me know if you solve :)
  3. Sidhu88
    Sidhu88 Active Member
    808
    76
    My leds are temperamental. If theyre on with the car not running itll turn off and i get the bulb fault. Run the car flick the lights in and off and itll be ok again
  4. tdi-man
    1,783
    64
    hi
    if you turn auto lights of i vag com wonderr if you still get fault
