lifting the back of the bonnet to let hot air out
harvey01 Mar 19, 2013
  1. harvey01
    harvey01 Member
    523
    9
    hi all has anyone lifted the back of there bonnet to let hot air out as ive done it with a few of my past cars but not shore with the s3. But as the turbo is at the back of the bay it should work ok
  2. James TQ
    James TQ Member
    561
    it catches on the wing and takes paint off
  3. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    Just no.
  4. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Just take the rubber sealing strip off that will let plenty of hot air out if that's what your after ;)
  5. <tuffty/>
    21,572
    4,046
    Just be aware that removing the rubber and/or lifting the bonnet at the back allows water to enter the back of the engine bay... have seen corrosion etc as a result
  6. Lemon S3
    Lemon S3 Alex
    1,390
    41
    This is only useful when you're stationary, the way the air travels over the bonnet when moving doesn't let any air out. This is not called the Venturi effect.
  7. 16Klappe
    5,795
    1,186
    No it's not?! There is no fluid pressures involved for it to be classed as a venturi, the technical term is "**** airflow."
  8. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Soz, you're right, confused myself with the proper meaning for the effect of pressure at the back of the bonnet. Still....lifting the bonnet doesn't make a difference when in motion.
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    And guess where the ECU lives....
  10. jojo
    28,931
    3,586
    Just remove the bonnet all together! :idea:
  11. bigwhitetruck
    bigwhitetruck New Member
    10
    The first reason for liftinG the bonnet was so u could shoe horn a bigger/taller engine in the bay without using differnt mounts
    mainly civics with 2.2 engines
  12. jimmcgee
    jimmcgee Active Member
    263
    41
    wrong , think rs turbo , way before jap ****
  13. Birdy
    Birdy Member
    70
    Put a Subaru scoop on it lol
  14. Gops
    3,198
    666
    Or a toilet flap or poop scoop like top gear?
  15. bigwhitetruck
    10
    Back in the day mark 1 rs ts had no bonnet vents so we used to fit them to let the heat out then ford released the mk2 Rs which came with vents in the bonnet and back in the day we wouldn't dream of ruining the lines by raising the bonnet at the rear
    i have been around a long time!
    And it was jap scrap in the states that started it
    It was a/is schoolboy mod
  16. superkarl
    superkarl MAN OF STEEL
    9,553
    2,453
    in summer i just take the seal out from the back of the bonnet just to let heat escape whilst moving slowly through traffic or whilst stationary. You can see the heat escaping. But it will only escape whilst stationary or not moving very fast.
  17. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
    This seal ?
  18. superkarl
    9,553
    2,453
    Thats the bugger!
    Lmao. How didnt i see that!
  19. s3clarke
    s3clarke Money grabbing s3!
    677
    35
    this is the bugger who stuck fingers (if that's what there called on a seal) in my turbo compressor wheel! Bent 1 of my blades the f*cker!
  20. mk1chopper
    mk1chopper Missing the S3
    1,092
    12
    It must have some effect whilst moving, hot air under the bonnet will have a higher pressure than the air flowing over the bonnet, the high presure air will want to go to the low pressure air, the gap at the back should act as a heat extractor. If you fit bonnet vents they dont force cold air into the engine they draw hot air out, some cars have vents in the wings, like the escort rs cosworth or clio 197/200 which work in the same manor. Although some cars do have a scoop like scoobys and GT4s that force air into the engine or intercooler on these cars.
  21. superkarl
    9,553
    2,453
    base of your windscreen/top of bonnet is going to be area of high pressure when moving. Compared to lower pressure under the bonnet. Therefore its not going escape. Its debatable that cold air might go in though
    And hence might actually be venturi effect by bernoullis principle
  22. A3-Lee
    A3-Lee Active Member VCDS Map User
    938
    226
    43
    This made me laugh so much lol
  23. Prawn
    11,575
    3,546
    You couldn't be more wrong.
    Base of windscreen is a high pressure area, not low, air will be drawn IN, not out by raising the back of the bonnet.
    Don't do it. No gains.
  24. Prawn
    11,575
    3,546
    thank god for superK, I tried to type that 45 mins ago but my net connection is so dire it failled repeatedly.
    Thankfully, Karl has already set the record straight.
  25. Jason.s
    Jason.s Active Member
    2,879
    348
    If only you could mount the filter right up under the scuttle for that high pressure. Bit like the Gruppe M intakes for EP3`s having the scoop on the scuttle.
  26. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    Just had to have a quick google on the Gruppe M kit for our 8L S3's.....
    To say their having a laugh with the price is a huge understatement!
    Buy Audi S3 8L 4WD 1999-03 Gruppe M Air Induction Kits | PPCGB
  27. jojo
    28,931
    3,586
    Wow, 900 quid!, no wonder no one has one! lol
    For 900, you could have a Badger5 3" and a Milltek cat back exhaust with a few quid change!
  28. Jason.s
    2,879
    348
    Gruppe M have always been spastic high on price but its nice carbon and they are good tbh but still i wouldnt ever pay for one lol.
  29. s3clarke
    677
    35
    Honda s2000 filter all the way!
  30. mk1chopper
    1,092
    12
    In principal I was correct, higher pressure will want to go to low pressure, but I hadnt taken into account higher pressure at the base of the windscreen. One question though if air is being forced in due to the high pressue at the base of the wind, is the air being forced in cooler than the air under the bonnet and would this have any benefits? Would lifting/removing the seal be benficial in certain circumsatnces, the high pressure area at the base of the windscreen will be speed relative,so say for example your are tracking your car which has several slow speed corners during these slow speed corners would you see lower pressure at the base of the windscreen and the reverse happening (heat extraction). The gains might be tiny but im just woundering if this would aid cooling in this situation.
  31. superkarl
    9,553
    2,453
    Without stupidly minute testing, you could never answer that.
    Based on the theories you could say the air going in would cool things. But who reeeaaally gives a **** for a few degrees
  32. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Hear hear! Plus people constantly tell you your bonnets open.
  33. Schlaag
    Schlaag Bwah
    472
    32
    No, you will look like a c*nt!
  34. s3clarke
    677
    35
    it just looks like you've had a front ender as well!
  35. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    It looks alright on a track car but not something I would want to do as there is no gain I guess.
    I supposed you could fit some washers on the bolts to raise it up a bit but im good with how my bonnet is now
