Lets get it on then, My 2.1 conversion
Andrew@A.L.D Dec 12, 2009
  1. Andrew@A.L.D
    3,879
    617
    fitted the front but need to fit these this weekend then bleed them all
  2. Smokey_clark
    Smokey_clark 12th Gear
    210
    Andrew you are such a tease! Can't wait to see this baby finished and running properly!!
  3. Andrew@A.L.D
    3,879
    617
    Thanks everyone
    You know when i got the car the plan was to keep it standard bar a remap, how things change when one thing leads to another when you have to rebuild the engine due to a big end knock.
    I'm really looking forward too getting her mapped and seeing how she stops on the monster brakes, as I'm on about the brakes i bet you can get bigger discs on under the TT 18's, I bet some 365mm discs could fit but what's 15mm anyway
  4. Andrew@A.L.D
    3,879
    617
    Fitted my brakes today but i've lost my wind back tool for the rears
    Also i've busted my V band clap on the exhaust so its off the road for a few days until the clap comes in the post
    Not the best pics
  5. Andrew@A.L.D
    3,879
    617
    F**king Hell !!! just tested the brakes and nearly went though the wind screen !!!
    I really need to be carful, they need bedding in also need to be easy with them
  6. jojo
    28,929
    3,583
    Love it!
  7. Andrew@A.L.D
    3,879
    617
    Brake are all sorted now
    I had a problem with the rear brakes binding but got that fix now as the slider was sticking
    All in all the brakes are great, the only problem i have with them is when you do jump on the stopper the ABS can go nuts as there is so much force with the 6 pots and the 350mm discs. The other problem is that the pad as super **** that give off lots of dust and people that i have spoke to said that they can fade fast so i will change them at a later date
    Fitted the S4 maf today also the engine seams smother and has better idle? I also had problems with the revs dropping fast but now the revs don't drop as fast, not sure if thats to do with the maf but hay its better
    As people know i had to lower the engine in the bay to get the turbo in there but its now showing up other problems like the CV joints are starting to knock a little but i thought that may happen as all the geometry is all out of whack with the different angles now but i will leave fitting new the CV joints till after mapping and coilovers are fitted
  8. badger5
    9,540
    2,016
    Hawk pads - you were warned!
  9. Andrew@A.L.D
    3,879
    617
    Came with the kit Bill and didn't have any knowledge of them but will change them for Ferodo DS2500
  10. Slammedorion
    Slammedorion Active Member Audi A3
    249
    76
    Might have a Bentley gt maf about if that's any use? Andy might still have one at his that's not being used?
    You'd have to sort a plug out for it. Give us a text if interested. Standard gt's are 560bhp and they still use the same maf's on the 650bhp models.
  11. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Paul Murray as in RSTuning Leeds? Can't think of a better man (apart from Bill) if so! Legend in Renaults especially.
  12. Andrew@A.L.D
    3,879
    617
    That it is. Paul Murray and andy speck at rst in Leeds will be mapping her
  13. JD09
    3,096
    46
    Had a look at Andy's Tigra?
  14. Andrew@A.L.D
    3,879
    617
    I have but it's in bit now as the engine went bang big time at about 700 bhp
    Forge had made andy a s**t load of custom parts for him and he wants to get it up ASAP for totb this year
  15. JS1500
    JS1500 Howdy
    1,166
    10
    Those discs are so big it almost looks like you have alloy look-a-like hubcaps!
    Epic 8L.
  16. badger5
    9,540
    2,016
    may be worth seeing when its running next when logging, determining which end is causing abs to come in soon.. It *might* be rears when the front ends diving, unloading the rear
  17. Andrew@A.L.D
    3,879
    617
    I do have a heavy right foot when it comes to the go and the stop pedal
  18. badger5
    9,540
    2,016
    logging wheel speed sensors when you next drive and make this happen will confirm which ends doing what, it may give an indication on brake "balance", which is essential in it not fighting the esp/abs system on the car
  19. Andrew@A.L.D
    3,879
    617
    Small update
    Ditch the Hawk brake pads as they were **** and gave off so much dust, fitted some cheap Red Stuff pads and must say they are great for the money.
    Booked the day for mapping
    5th of Sept at RS Tuning , fingers crossed for some good Poweeeeer and Torques numbers
  20. cole
    cole New Member
    any updates on this thred pal
  21. Andrew@A.L.D
    3,879
    617
    Sorry nothing yet as i did some minor work on it over xmas and will get it booked in for mapping when i sort the wiring out for the BAM ecu
  22. How much has it cost you so far Andrew, if you dont mind me asking?!
  23. Andrew@A.L.D
    3,879
    617
    Not added it up and not going to
  24. Andrew@A.L.D
    3,879
    617
    More problems
    As you may or may not no i have had a idle problem with my car
    I changed the brake booster pipe today thinking it was that but that hasn't helped at all and to be honest its made things worse.
    There is a loud hiss from the bulk head which i thought was the booster hose? but it is coming from around that area? This hiss has got louder when you drive. All boost hoses look fine?
    I took the lambda out and wiped it clean, i did notices that rattled when i shuck it but put it back in
    I've looked at the liquid at the air fuel ratio and thats doesn't seam to be making much adjustments? it only goes up and down a very little? .940 been the max and .938 been the lower?
    I did make a little progress on other things, I did manage to make a 4 in tip with Stainless steel Blitz air filter today before everything else went pear shaped
    tony696 likes this.
  25. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    Looking very good andrew better than the standered look in my eye pal
  26. Andrew@A.L.D
    3,879
    617
    Another problem solved
    The hiss was the new hose and the new rubber seal split :wtf::banghead: That off now and will be making a new one of of metal
    Thanks gazz
  27. Big Bang Yam
    Big Bang Yam Member
    59
    one of the top 3 builds on here! take a bow
  28. Andrew@A.L.D
    3,879
    617
    Lots has happened since i did last did a update
    I'm just lazy really
    Should start another or update this with a title saying lets get it on my 2.1 part 2 as it been rebuilt with lots of new stuff
    More to come thats when i can be bothered lol
  29. <tuffty/>
    21,566
    4,045
    You want to create a thread with links to all the other ones you have done mate LOL... they are all over the place :)
    (let me know if you need any help ;P)
  30. <tuffty/>
    21,566
    4,045
  31. Andrew@A.L.D
    3,879
    617
    I'm going to have to keep this up to date
    As she stands
    After that cam snapped it destroyed the head so i got another AEB head from Dani, It was ported to race spec and rebuilt with new valves as 2 were bent
    Rebuilding the engine with a new block as there were a few scores in the bore i didn't like
    Its now at the machine shop getting bored out
    I also had problems with the CPS wheel coming loose so that was tiged in place without any worry of it coming loose again
    Just waiting for some ARP main stud kit to turn up as i stretched the standard bolts and some new tool steel wrist pins as i crushed the mild steel ones but it was lucky i stripped the engine down when i did the cam as i wouldn't of know of these problems.
  32. Scullies
    Scullies Well-Known Member
    1,543
    658
    Is it easier to take the engine out and leave the gearbox in?
  33. Andrew@A.L.D
    3,879
    617
    Very easy
    The head was off at the time, just took the pulleys of the side of the engine to give more clearance, unbolts it from the gear box, pull the engine to the side and drop it down
  34. badger5
    9,540
    2,016
    muchos cyl pressures..... stretching head bolts.. You were on st dones before? (surprised, given the big spec of everything else).. bending wrist pins too... good work.. hehe.. nutter andrew :)
    i luv seeing your port work... work of art.
  35. Andrew@A.L.D
    3,879
    617
    If i knew what i know now i would of built it differently thats why i'm doing it right now. Just so glad the cam snapped now and i stripped it down to inspect and clean as if it didn't i would of kept on thrashing it about and might of gone in a really big way taking out the engine and turbo!!.
    I had ARP head bolts but standard mains, swapping to ARP main stud kit now and swapping to tool steel wrist pins
    This head is so much better than the last head and should flow a lot more as its showed good gains on the flow bench
  36. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    omg, a massive amount of time and work, hats off to you andrew, and i agree that head looks better than mayonayse ozzing out of a spam sandwich :)
  37. Andrew@A.L.D
    3,879
    617
    Had some good new with a email from summit racing saying my tool steel wrist pins are on the way
    New HD main bearings, race big end bearing and new rings came today. Still waiting on the ARP main studs but shouldn't be too long.
    Block is still at the machine shop
  38. Sneekyparrot
    Sneekyparrot Member
    45
    What a cracking read. Love these type of build threads :)
    once i start on the motor the AGU head i picked up is defo heading upto Andrew for some treatment!!
    P.
  39. Andrew@A.L.D
    3,879
    617
    not a problem
    done about 20+ 20v head now from small to large port heads
  40. Andrew@A.L.D
    3,879
    617
    Time for a little update
    The ARP main studs came so i got them fitted today along with my modified crank as it was in the CNC machine i decided to double dowel the crank to the flywheel. This is to stop the flywheel from turning on the crank even thought the bolts are torqued up, Stacey is using a diamond shim plate, The way i have done it works in the same way as the shim..
    Engine almost fully built
    All done
