Lets get it on then, My 2.1 conversion
Andrew@A.L.D Dec 12, 2009
  1. Andrew@A.L.D
    3,879
    617
    To make room for the CO sensor i just made a spacer plate to put the turbo down 5mm and that gives it more room
  2. Andrew@A.L.D
    3,879
    617
    Little update
    With the long weekend i've been working on the car as much as i can as well as doing some cylinder head work for a customer
    The bottom end is in, clutch bleed etc etc
    Just need to fit the down pipe and the rest of the Milltek, Turbo and head and everything else that goes with it
    I hope to get it running by next weekend
    Taken with a phone cam
  3. Andrew@A.L.D
    3,879
    617
  4. CraigHarrison
    CraigHarrison Member
    118
    Sweet! Great work!
  5. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    awesome project mate! cant wait to see it finished
  6. Andrew@A.L.D
    3,879
    617
    Thank you
    Just loving the stealth look engine bay. wasn't sure at first but i do now
  7. Andrew@A.L.D
    3,879
    617
    Its the big day tomorrow and the engine will be started when i refit the battery and a extended hoses from the BAM Tip
  8. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    good luck mate!
  9. Andrew@A.L.D
    3,879
    617
    She runs !!
    Timing still out:banghead: but other than that even with the timing out she pulls really strong, turbo kicks in very early about 2k and pulls hard upto 4k don't want to take it upto any more with the timing out and still having to run it in
  10. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    Good news though it lives.
  11. Chlippo
    Chlippo Member
    679
    15
    Thats very nice man! keep it up
  12. Andrew@A.L.D
    3,879
    617
    Think i've sorted the timing but i now have another code coming up
    17745 P1337 Camshaft Pos.Sensor Bank1 Short to Ground
    Any idea's
  13. Andrew@A.L.D
    3,879
    617
    Little update
    Haven't driven her much as i've been having trouble timing in the engine and i think i know why
    The head was second hand as my APY one was dead so i got one off ebay with unknown history but now know its been skimmed to much for standard compression, luckily my 2.1 is running low compression pistons said to be 8.5:1, with the head been skimmed a few times i've worked it out to be 9.4:1 with the thinner head gasket, The C/R is almost standard but with the head been skimmed and the thinner head gasket its shortening the belt thus throwing a fault code up every time.
    I got onto Cat Cams and ordered a adjustable pulley that will be able to fine tune the timing rather than been a tooth off on the belt.
  14. Andrew@A.L.D
    3,879
    617
    Timing all sorted today with the help of the pulley
    Made life a lot easier, there would be no way i would be able to get the timing spot on with the standard pulley
    just got to drop a bit of oil as its over the level as it smokes a tad when revved
    Also have to get rid of the dash warning light with the sport cat
  15. DaveA3
    2,370
    15
    gratz mate! hope its running perfect soon :D
  16. Andrew@A.L.D
    3,879
    617
    Just a little update
    Since the 2.1 build i was worried about the turbo and its history so it has now been to CR Turbos for a rebuild to stage 3
    Also fitted 4 new coil packs, CO sensor, Air temp sensor and other little things
    I've now got a catch can thats going to be fitted this weekend also a 4 bar fuel reg if i need it for mapping and on the look out for some VXR 440cc fuel injectors
    Fitted some face lift lights and thanks to S3_Kev for the info
    Just got to get a MOT and then i will get it booked in for mapping once i'm happy with everything
  17. Smokey_clark
    Smokey_clark 12th Gear
    210
    Hows this project going? I've been enjoying the read so please don't stop now dude!
  18. Andrew@A.L.D
    3,879
    617
    Had some problems with it since the build the engine over heated and damaged a few of the bearings and maybe some of the rings so its been stripped and rebuilt with new bearing, polished crank and Total seal piston rings
  19. Andrew@A.L.D
    3,879
    617
    After the little problem i have had with the over heating i decided to inspected the engine and found that as it over heated it did some damage to the big ends to out came the engine and stripped right down, the crank was polished as the damage wasn't that bad, i also noticed the rings had got hot to so i replaced them with some Total seal rings. I've also fitted new bearing and the bottom end is back in the car.
    As the engine was out i modified my breather and catch can and happy with the fitment now
    I also took the time out to paint the door moldings, front grill and rear section of the bumpers satin black as mine were badly faded
    It look 100% better than what it was and even better with the facelift head lights
    After seeing Tuffty doing the Golf R32 Throttle body conversion i thought i would have a look on ebay and tame across a few of them, one Tuffty got before me, One that was brand new and paid for it as a buy it now price of £99 but the seller came back to me and said that it was a double post? Bull***t !!. Anyway i posted the part number on on google and i found one on Germany Ebay for a £65 !!
    I'm just on the look out for a S3/TT inlet and making a adaptor plate that will be welded on then ported to match
    If that fails i will make my own plenum
  20. Dani_B19
    9,382
    403
    Hope it all goes well this time round mate. Didn't you used to run pre-facelift headlights?
  21. Andrew@A.L.D
    3,879
    617
    Spent a lot of time making sure it will be ok this time round
    I did run the pre-facelift ones, never like that look of them
  22. finesse
    finesse Active Member
    2,805
    cool
  23. Dani_B19
    9,382
    403
    Where did you get the facelifts from? Whats it like fitting etc?
  24. Andrew@A.L.D
    3,879
    617
    There none Xenons Dani
    Kev did the same and fitted none xenons, i don't drive much at night as i'm partly blind in one eye.
    I got them from Ebay at £55 each and the wiring is just a plug and play but the only modifications you need to do is trim part of the wing
    Must fit these before mapping too
    Also looking at fitting a 2nd fuel pump to make sure the std pump doesn't give up the ghost
  25. Dani_B19
    9,382
    403
    Ooh i get you, sorry they looked like xenons, yeah i remember kev's thread, think i may have to do it myself and just fit a HID kit.
  26. Andrew@A.L.D
    3,879
    617
    I plan to fit the HID kit maybe?
    Not the 1st thing on my to do list just yet
  27. Andrew@A.L.D
    3,879
    617
  28. Andrew@A.L.D
    3,879
    617
    Just spent the last few weeks doing more portering work on my cylinder head and managed to get over to my friend workshop to borrow his flow bench and managed to gain more cfm's out of my work done on it and also found out that it has better flow than the CNC small port heads out there now. God know what i'll gain if i did a large port head.
    Anyway the head is all built back up again and will be bolted back onto the block tomorrow
    No pictures of the head sorry
  29. Andrew@A.L.D
    3,879
    617
    Started her today and all is well, now smoke, runs smooth, and stays cool, had a little water leak from the thermostat but took 20mins to fix
    Bring on the MOT and to run her in before mapping, I would of got her done sooner but i just have been so busy with work i just didn't have time to work on my own car.
  30. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    top work mate
  31. Andrew@A.L.D
    3,879
    617
    Going to get a few miles on it and then get it into the body shop for paint then map it
  32. Andrew@A.L.D
    3,879
    617
    Well it failed its MOT but only on the emissions now which is running 0.600 rather than the 0.200 something wrong somewhere but i will be getting it into a diagnostics place to find the problem.
    When thats done i will be road legal and start to put the miles on the engine before mapping but i have a few more modifications to make to the engine before i do, one is the R32 throttle body and VXR injectors, i also plan to fit a second fuel pump to help with the feed of fuel.
    I have driven the car with the new engine and it has a hell of a lot or torque and thats before mapping. The boost limit comes in and stop the fun at about 3k but i have not disconnected the N75 for now until run in.
    Going to get the Jamex coilovers ordered this weekend and will also be popping round to see S3Dave to buy some of his stainless steel tie arms, i would of made some myself but once i've paid for the S/S made a jig and got some spare tie bars the cost would be the same as daves so his are a good price a look well made also.
    Also i took delivery of my wheel spacers and went for 15 from and 20 rear. I got the spacers from the TT shop as they sell them as a kit with bolts and locking bolts.
    Also fitted my catch can
  33. <tuffty/>
    21,897
    4,206
    Nice work mate... might see if mine will fit there.... can you get to the drain easy enough?
  34. Andrew@A.L.D
    3,879
    617
    Thats the fun bit and in one word.... No... very hard to get to
  35. <tuffty/>
    21,897
    4,206
    Boo :(
    Will have to have a look into that then ;P
  36. Andrew@A.L.D
    3,879
    617
    I have to many pipes there and also it makes it hard with the TIP in the way.
    When i move my battery to the boot i will move it to the engine bay battery box
  37. tompearson
    tompearson It's all in bits
    219
    You can get a flange for the turbo return that lets you plumb a catch can drain into the sump from 034. That might make life easier.
  38. Andrew@A.L.D
    3,879
    617
    I was looking into making something like that depending how often i have to drain the tank?
  39. Andrew@A.L.D
    3,879
    617
    Found out why the emissions were so high for the MOT, The cat was fooked due to oil form when the head gasket went and the piston ring problem. I have a new down pipe and cat coming from relentless which i will replace the cat and cut up the damaged cat pipe and make a decat pipe, i will be keeping the down pipe as i will be cutting that up for when i go big turbo so a little less fab work will be needed.
    With that problem sorted i started back on the modifications, My Jamex coilovers have come and will be popping up on saturday to see s3dave for some of his tie arms, i would made some myself but i don't have the space to take them off my car to make a jig. As i'm at Daves i will pop into my local VW to order the R32 ARB's and bushes.
    I have also purchased a liquid gauge and will be getting that soon, I can't wait for that as its a great bit of kit i really need.
    I'm also making up a adaptor plate for the R32 throttle body i have and i've also ordered all the hoses needed to fit it
    Fitted the the spacers and my god they transform the look of the car, I had my doubts with the 15mm front and 20mm rear but they seam just right and when the coilovers are fitted will look even better
  40. superkarl
    superkarl MAN OF STEEL
    9,611
    2,481
    any chance you could upload some pictures of your car? :)
