Lets get it on then, My 2.1 conversion
Andrew@A.L.D Dec 12, 2009
  1. Andrew@A.L.D
    3,877
    617
    As some of you know my big end when after a oil pump failure some time ago and at the time i was trying to get it sorted with the garage i got it from but no such luck.
    Anyway the engine was stripped to find that the crank was damaged beyond repair and there were scores in the bores as well as some pitting? A second hand engine was my first choice but there a bit thin on the ice and if i did find one people were wanting a lot of money for them and had no history for the engine. The second option was try to find a good S3/TT crank? how wrong again as they are like rocking horse poo but i was offered a 1.9TDI crank and was told that they could be used as part of a stroker kit. I handed over £150 for the crank and walked away thinking what am i getting into know lol.
    What to do next? build the engine with what i had I did my research and found pete @ Integrated Engineering very helpful and i have now handed over $1600 USD to pete@IE for a stroker kit giving a 2067cc engine and 8.5:1 compression but still safe to 6500+rpms and some performance valves set with inconel exhaust valves
    The rest of the engine has been inspected and found to be good, The head will be fully stripped down cleaned and ported by my own hands as this is what i have been doing for many years. It looks like the head can be improved a lot around the exhaust ports as there is a 5-6mm difference in port size of the head and the manifold and some modification will be done to reduce carbon build up, improvement of of flow, knife edging the split ports on the inlet and will be given a light skim and so on.
    When the engine is build it will be run in and a down pipe and exhaust system will be fitted at a later date as well as a remap to make the most of the 2.1 engine, when i get the spare cash the rest of the car will be give a look over on chassis modifications and then a big turbo conversion will be considered depending on money?
    Picture will come soon of the damage engine and new parts
    But for now here is the car in question
    Car before ebay intercooler fitted
  2. S3 HODGE
    S3 HODGE Brown passenger seat.
    1,200
    Sounds good, Shame about the mess up with the garage. Hope all goes well.
  3. Andrew@A.L.D
    3,877
    617
    I only has the car 2 and a half months before the oil pump went and they refused to fix it ignoring all my letter and fobbing me off when ever i ring, Trading standards didn't have much luck ether so i'm fixing it and throwing in some performance modifications.
    I will take them to court for them to pay up for the standard parts put on the car, crank, big end bearing, bolts etc etc to see if i get paid out?
    But anyway let the fun begin with this engine
    BTW stay away from Blackburn Motor village trade centre
  4. Ash B
    Ash B Well-Known Member
    5,831
    This should be interesting i will be keeping an eye on this thread:)
  5. Andrew@A.L.D
    3,877
    617
    It should be good when done as it will produce loads more torque than the 1.8 so very drivable.
  6. Andrew@A.L.D
    3,877
    617
    Ok a little update as i got the camera out today to take some pictures of some of the damage and modifications been done
    Lets start with the damage
    Main bearings
    The modifications to the head as you can see the gasket on the head, the gasket lines up with the ports on the manifold but not on the head so i did a little bit of portering to match them
    Before
    After
    Still have loads of work to do on the head as i will fit new guides and recut the seats as there is a bit of play in the valve guids
    Picked up a brand new sump today
    Painted my cam cover, boost pipe and inlet in crackle black
    All sat on my parts washer read to be fitted
  7. <tuffty/>
    20,996
    3,762
    Good luck mate... I assume you aren't using the TDi crank non and just bought a stroker kit from IE?
  8. Andrew@A.L.D
    3,877
    617
  9. <tuffty/>
    20,996
    3,762
    Ahhhhhhh, nice one... retains the 1.8t block... interesting... suggests no clearancing either... again, interesting...
    One to watch methinks :)
  10. Andrew@A.L.D
    3,877
    617
    The head work is going to one to watch as i have a friend with a flowbench 110 so we will do testing on that
  11. Andrew@A.L.D
    3,877
    617
    Little update
    Finished off the exhaust ports today
  12. Kunit
    Kunit Member
    170
    Damn nice head work, plenty of material removed. How many hours to do?
  13. Andrew@A.L.D
    3,877
    617
    I would say about 2 hours on the exhaust ports, more on the inlets.
  14. Kunit
    Kunit Member
    170
    2 hours! Im guessing this is you forte? Any pics of the inlets? Im guessing they wont be polished?
  15. Andrew@A.L.D
    3,877
    617
    It is sort of, not started on the inlet yet.
    they wont be polished at all as thats not good for the fuel and air mix
  16. Dani_B19
    9,161
    360
    Andrew arnt you based in leeds?
  17. Kunit
    Kunit Member
    170
    Not good unless you want the mix to stick to the sides and dribble into the bores. Be good to see the flow on it once finished
  18. Andrew@A.L.D
    3,877
    617
    I am based in Leeds Dan
    Kunit i know about all that stuff you could say i now it very well
  19. Andrew@A.L.D
    3,877
    617
    This is a Focus ST170 head i did for a customer i did this year
    I will be testing my head on a flow bench when done and then take measurements of the work done and repeat them again if i have to do another
  20. Kunit
    Kunit Member
    170
    Makes me want to pull the head off mine now but im definately not as good as you!
  21. Andrew@A.L.D
    3,877
    617
    Thank you plus my prices arn't that bad either ( shameless plug lol PM me if you like about this work )
    But lets now talk about the work i can do to head and get back to my 2.1 build.
    I should get my pistons, rods and valves in the new year, the engine will be out of the car by sunday. I will order a uprated clutch on the weekend and the gasket kit so will have everything for the bottom end.
    My be looking into making a manifold for a GT30 conversion in the new year if found let me
  22. Prawn
    11,444
    3,339
    interesting conversion, I've never seen figures for a 'built' engine running a standard turbo....
    I assume you'll get quicker spool up and higher torque from the larger capacity? although potentially lower maximum boost capability at the upper limits of the compressor due to a larger space to stuff it into?
  23. Andrew@A.L.D
    3,877
    617
    Not sure myself as i haven't seen any S3 running a 2.0/2.1 with K04 still?
    I will still keep the K04 until run in and when i get the cash then go GT30?
  24. S3 HODGE
    1,200
    Looks good mate. This is one to watch.
    GT30 all the way! :respekt:
  25. <tuffty/>
    20,996
    3,762
    8P S3's do it all the time :)
  26. Andrew@A.L.D
    3,877
    617
    I can wait to see what it does after a bit of mapping
  27. Essflee
    Essflee Well-Known Member
    2,142
    66
    Lol... Dirty boy
  28. Westy
    Westy Well-Known Member
    17,443
    1,103
    Brilliant :laugh:
  29. badger5
    9,424
    1,968
    it should spool early, have strong torque but run out of puff earlier in the revs as the k04 compressor runs out of supply whilst the exhaust manifold and hotside chokes.
  30. Andrew@A.L.D
    3,877
    617
    Thanks badger now i'll have to save the penny's now you've said that
    Also have you hand much experience with the GT30HTA Turbo's?
  31. Andrew@A.L.D
    3,877
    617
    A little update on the head
    Done some of the inlet ports and must say there not the easiest things to porter but i got it done, you can see the standard inlet and the finished one, not the best picture as its in **** lighting.
    Also cleaned up the combustion chamber
    standard inlet port
    Modified port
    Cleaned combustion chamber
    When done it will be going in for a light skim, new guides and recutting the seats
  32. badger5
    9,424
    1,968
    no personal experience, but they have a good rep for improved spool over their normal "cousins"
    GT35HTA is on my list to try one day if I need to review my existing GT35R
  33. Andrew@A.L.D
    3,877
    617
    little update
    Been working on the car today in the snow its been slow but its time for the engine to come out now, managed to strip most of the engine down in the bay so the only thing left on it is the crank, flywheel, clutch, pulley and thats it. Just need to borrow a crane to get it out but that will be when the snow is gone.
    As i had to dismantle part of the gear linkage on the box i notice the bush's on the brackets have seen better days to i will get in to the workshop to turn some metal bushes and hope to make it a bit more positive when shifting
  34. Andrew@A.L.D
    3,877
    617
    Another small update as i'm waiting for parts from IE
    The head has been tested on a friend flow bench and has gained of 10.5% increase in flow on the inlet and 15% on the exhaust witch i thought wasn't than much but was told thats very good gains from that head. More can be had from it if i was willing to put the time into it witch i will be doing with another head but this one will be used for mine as it is.
  35. Kitchy
    Kitchy Member
    92
    nice work as usual mate! look forward to seeing it the car
  36. Andrew@A.L.D
    3,877
    617
  37. Andrew@A.L.D
    3,877
    617
    Got these today after having to pay a small charges
    JE 83mm forged pistons for 2067cc
    IE Steel rods
    Performance valve kit
    No pictures of the crank yet but i will
    Also waiting for a single mass flywheel to come so you will get pictures of that, just need to take the block to the machine shop to get it bore out as the is loads of damage to No 2 bore as at some point in its life its drop a valve or two as some major scoring.
    Brazuko likes this.
  38. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,143
    1,974
    Andrew :applaus: you are doing something which I think a few of us would fancy if we had the time/balls/money
    well done
  39. Andrew@A.L.D
    3,877
    617
    I wouldn't of done it if it didn't spin a bearing and found out the bore had had it
    But Pete at IE did me a great deal on the parts and thought i would go for it
    Just got to get the cash together to get a GT30 or 35 Turbo on it when done
  40. Andrew@A.L.D
    3,877
    617
    Got the engine block and head back from the machine shop and now has a 83mm bore and a nicely skimmed head
    Block is painted crackle black witch doesnt look that good in the pictures but it does look good in person and its very high temperature paint
    Started to get the bottom end together and ran into a few little problems, with the now 95mm stroke the pistons hit the oil jets so i tried to space the oil jet out of the way with some 2mm spacers but thats just not enough and if i go any more one of the jets will hit the trigger wheel for the CPS so the pistons will need machining witch i will get pics up when done
    The trigger wheel was also a problem as the bolt holes didn't match TDi crank ones so i modified the S3 ones to fit but i have now found out that you can use one from a 2.0 8v ABA engine that will bolt on.
    With the block back i thought i would cheap the head gasket and all is well with the ALH N/A 2.0 Passat gasket
    Spent most of the day lapping all my 20 valves in and rebuilding another head for customer but had to stop with my head as euro car parts gave me the wrong valve steam oil seals
    Now for lots of random picture
