Hi,
I have had an odd problem with my A4 2004 B7 since I got it a few weeks ago.
All doors lock fine with central locking, but the rear left door won't open unless you open it from inside the car. Once it's opened once from inside, it will open from the outside OK.
I have the following fault code:-
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BM
Component: Komfortgerát T3B 2431
Coding: 06395
Shop #: WSC 06335
VCID: 7DFAFBAA1BAB78F4
Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0205
Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0205
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
1 Fault Found
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
I've visually inspected the wiring going into the the door module, and it appears fine, although I haven't tried a continuity test.
There is a replacement module available on ebay:-
AUDI A4 LEFT REAR WINDOW REGULATOR MOTOR 8E0 959 801 A | eBay UK
Anyone had a similar issue?
Thanks in advance
Cheers, Lee
Coding: 06395
Shop #: WSC 06335
Part No: 8E2959802B
Part No: 8E2959801B
Part No: 8E0959801A
Part No: 8E0959802A
1 Fault Found
Thanks in advance
Cheers, Lee
