  1. simon.m
    simon.m Active Member
    2,747
    hi all i just got some AUDI SIDE LIGHT 501 CAPLESS 12V LED BULBS XENON WHITE
    501 LED light bulbs, also known as W5W, 194, T10 or T11,wedge base. my ? im told they go in with no problems
    any one got them and no if they make any problems befor i put them in
    thanks
    simon :icon_thumright:
  2. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,917
    196
    I've got the single led type, no probs atall.
  3. J7USS
    J7USS Shuddup Foooool!!
    3,737
    76
    Ive also got them, no probs at all.make a huge difference too!
  4. simon.m
    2,747
  5. mattyboyc
    1,917
    196
  6. scott b
    scott b Active Member VCDS Map User
    1,254
  7. simon.m
    2,747
    yep i got them from the same guy though just for got i looked at the blue ones first lol
  8. niftyandy
    niftyandy Member
    100
    Hi
    I've just tried a couple of these as replacement sidelight bulbs...but even tho the blurb said they wouldn't give DNS errors...suffice to say they did and all they did was flash on and off all the time...should I be looking for a particular type?
  9. simon.m
    2,747
    are they the same ones as i got ?
  10. alipaton
    alipaton Member
    112
    i had this problem aswell the sidelights just flashed .i just gave up and stuck with regular bulbs .would be intresting to know wether it was the bulbs or just my car didn.t like the led's
  11. simon.m
    2,747
    im thinking and hoping i dont get any problems as my DNS dont show if i have a light out so may not pick up the leds.
    if they flash im thinking i should have got the blue ones lol would come in handy hahahaha
  12. quattrojames
    14,050
    574
    I've linked to these plenty of times before, I know J7USS had a bad experience with the seller, but everyone else who has used them have found them error free as far as I know, and they now come in a 15 led version too. I have the 9's and rate them very highly.
    9 LED Version
    15 LED Version
  13. simon.m
    2,747
    well if the ones i have mess around ill buy some of the ones you have james.
    are they hard to fit hoping i dont need to take the hole unit out
  14. quattrojames
    14,050
    574
    If you can fit the other ones without taking the light out then you will be able to do the same with these, personally I can't fit my hand down the back of the light so find it easier just to take them out.
  15. simon.m
    2,747
    ahhhh ill get my 11 year old son to do it lol
  16. niftyandy
    niftyandy Member
    100
    I tried the 4 led directional (ie just ahead) ones and the 5 led all round ones...they both flashed...I eventiually got some 'normal' LED 501...mad a good rather than big difference!
  17. simon.m
    2,747
    i thought the ones i got are 501
  18. niftyandy
    niftyandy Member
    100
    Then you're probably ok....my flashers were the LED diode bulbs rather than a 'normal' bulb filament etc.
  19. 1210tech
    1210tech Four Ring Fanatic
    692
    Its not the fitment type that makes a difference whether the LED's flash on & off, its whether they have resistors built into them. The ones that James linked to have resistors built into so they don't throw errors up on the DIS or flash on & off.
    When you are searching for sidelight LED's on eBay add 'No Errors' in the search box so it lists the ones that have resistors built in.
    I have bought a couple of the 9 LED type that James linked to but they are too blue to match my 4300k xenons, they will match 6000k perfectly.
    Heres a few pics of the colour differences between standard filament bulbs, blue filament bulbs and then 9 LED sidelights.
    Standard filament
    Blue filament
    9 LED diodes
  20. quattrojames
    14,050
    574
    Nice pics mate, they capture the different colours really well :icon_thumright:
  21. simon.m
    2,747
    that they do im really hoping the ones i have coming are not going to flash ;-(
  22. niftyandy
    niftyandy Member
    100
    Tell you what...
    I've got some 5 led versions with 4 LEDs around the stem and 1 at the end, pointing forwards.
    Ive just tried them in the boot and footwell bulb holders and they fit well...The holders will take the 9 led version but not the 15's as they're too long.
    I bet the interior lighting (footwells and boot) would look really cool with 9's in, esp the boot which is a bit feeble considering its size!
    Worth a try!!
  23. Kostas
    Kostas Member
    104
    i've got 15 LED towers in and also think they are too blue for my k4300 what about blue filament bulbs do they match better? can you put a link where did you get them? ohh and then i put the ignition on my towers blinks four times does anyone else expirience this?
  24. 1210tech
    692
    these are the blue filament ones I bought that are shown in the second picture: Audi Xenon White sidelights
  25. simon.m
    2,747
    so led`s come today put them in and they work fine no flasing on error codes :icon_thumright:
    iv asked this before but cant for the life of me think how to do it so have to ask again
    how do i post a photo.
  26. 1210tech
    692
    upload your photo to Photobucket, click on Insert Image button and copy the IMG code from Photobucket into the Insert Image text box :icon_thumright:
  27. simon.m
    2,747
    so before
    after
