LED Sidelights and Xenons
RichA3Turbo Nov 16, 2004
  1. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    This is just a post to show the LED's that 'CAGE' sells against xenons... they are white 4 LED bulbs in a plastic casing (believe it or not, just like a bulb!) and a bargain too at £11 a pair. I bought some other i had to modicy to fit and didnt bloody work! These are good 'uns tho!
  2. RichA3Turbo
    5,089
  3. RichA3Turbo
    5,089
  4. RichA3Turbo
    5,089
  5. neversaydie
    neversaydie Post Whore
    1,762
    Yewp - they are good int they Rich brought some my self - so I can confir they are a cracking deal from Cage!
  6. RichA3Turbo
    5,089
    Yep... will look better when i get around to doing the facelift lights... WHENEVER THAT may be /ubbthreads/images/graemlins/smirk.gif Got such a long list, its rather low down on priorities at the moment
  7. neversaydie
    1,762
    Dito, but Im sure I'll squeez them in at some point - while were on this topic of other mods....
    Off to AMD the wonderful land of Mods, Would you recomend Eibach Springs and dampers?
    If not What and where?
  8. imported_YOGi
    imported_YOGi Guest
    Where can i find these Rich, can i have a link/number please? They look the nuts! Are they road legal?
    Thanks YOGi
  9. neversaydie
    1,762
    Find Cage online or PM him
  10. imported_Rooney
    imported_Rooney Guest
    Are they easy to instal?
  11. Masterm8fo
    Masterm8fo Warmonger
    342
  12. neversaydie
    1,762
    Piece of cake to install and it only take 5 mins max! /ubbthreads/images/graemlins/groovy.gif
    TBH it was more effort to open up the car lean down, pull the bonet catch, get out and then lift up bonnet than it was to install these babies!
  13. Drill
    Drill Member
    928
    <font color="red">WARNING!!!</font>
    Some of these bulbs come with a clear plastic "cap" which diffusses the light in such a way that it looks more like 1 bulb as opposed to the 4 seperate LEDS. I personally prefered this look, HOWEVER, when pulling the bulbs OUT (for instance, when they blow/wear out) this cap can come loose and possibly fall INTO the headlight housing. The only way to get it out is to pull the headlight apart /ubbthreads/images/graemlins/crazy.gif So if you use this cap, make sure that joker's on there TIGHT /ubbthreads/images/graemlins/angel.gif /ubbthreads/images/graemlins/grin.gif
    Just a helpful hint /ubbthreads/images/graemlins/wink.gif
    /ubbthreads/images/graemlins/beerchug.gif
  14. RichA3Turbo
    5,089
    No problem here drill... They are 4 separate LEDs with no diffuser luckily... but good advice none the less
    Rich
  15. Drill
    Drill Member
    928
    Well, I've seen the 4 LED ones with the cap. Matter of fact, those are the "cheap" (Figuratively of course /ubbthreads/images/graemlins/crazy.gif) white ones that only lasted about 2 months /ubbthreads/images/graemlins/frown.gif When I pulled them to replace them, the cap fell off into the housing /ubbthreads/images/graemlins/burningmad.gif So I had to pull the damned light out to get it /ubbthreads/images/graemlins/mad.gif Talk about a PITA /ubbthreads/images/graemlins/smirk.gif
  16. NWMark
    NWMark Member
    211
    14
    [ QUOTE ]
    [/ QUOTE ]
    [ QUOTE ]
    Drill said:
    Well, I've seen the 4 LED ones with the cap. Matter of fact, those are the "cheap" (Figuratively of course ) white ones that only lasted about 2 months
    [/ QUOTE ]
    Ive just got mine from cage and mine have the caps, does this mean i got the cheap ones /ubbthreads/images/graemlins/cry.gif
    Mark
    p.s. how the hell do you remove the bulbs, 1) i cant get my hand in to grip the rear of the bulb 2) it wont budge when i get a couple of fingers around to grab it, do they twist or something?
  17. NWMark
    NWMark Member
    211
    14
    Im sure someones super glued my bulbs in.
    Has anyone changed these bulbs on an S3 and still has the full use of their hands!!!!
    Will have another go tomorrow, do the holders just pull out or twist?
    Mark
  18. neversaydie
    1,762
    They are fewkers to get out, especialy the drivers side for some reason... Pliers did the trick for me, dont crush them though!
  19. Cage
    Cage Member
    95
    PM sent MikeyD
  20. nervus
    nervus Well-Known Member
    1,384
    124
    Same here cage, i also have a 2003 S3, can you pm me details of how to pay etc. i would also prefer the ones without the caps if you can /ubbthreads/images/graemlins/grin.gif
  21. L1ARR
    L1ARR Active Member
    439
    44
    Cage sent you a pm and Payment can you also send me the bulbs with no caps as I also have a 2003 S3.
    Dicky Boy
  22. Drill
    Drill Member
    928
    [ QUOTE ]
    NWMark said:
    [ QUOTE ]
    [/ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    Mark
    [/ QUOTE ]
    Mark, I doubt they're the same brand I picked up locally here in Germany dude /ubbthreads/images/graemlins/grin.gif So I can't testify to the quality, just wanted to be sure folks were warned about them damned Caps /ubbthreads/images/graemlins/lol.gif
  23. monty77
    monty77 Member
    391
    [ QUOTE ]
    Cage said:
    [ QUOTE ]
    [/ QUOTE ]
    PM sent /ubbthreads/images/graemlins/wink.gif
    [/ QUOTE ]
    Cage, did you get my pm last week? Still no sign of my LEDs.
    Ta,
    Adam
  24. Cage
    Cage Member
    95
    PM sent
    LED's were posted last week Friday.
    OILBURNER: Still awaiting a reply to my PM also.
  25. JamS3
    JamS3 Active Member
    2,258
    24
    I'm thinking about these now too looking at the pics.
    Think the sidelights will look so much better next to the xenons now with these!
    How long are they expected to last and iv'e heard about some problems with the DIS flashing up warnings when they have been fitted, is there any truth in this?
  26. stealthgr
    stealthgr Member
    34
    can you inform us ignorant about the xenon and the sidelights you are talking about?
    any pics etc?
    thanks
  27. JamS3
    JamS3 Active Member
    2,258
    24
    The xenons are the main lights you have on when you are driving, you will have seen them on other cars, much brighter and the light looks really blue.
    The sidelights are "position" lamps and not the bright ones you use to drive in the dark. These bulbs that Cage is selling makes the sidelights look alot similar to the xenon lights already on the car.
    I think ritch posted some pics on page 1 of this topic.
  28. RAPS3
    RAPS3 Well-Known Member
    1,142
    135
    Fancy some of these too.
    Cage you have PM
  29. JamS3
    JamS3 Active Member
    2,258
    24
    Iv'e ordered some too Paul, we will have to make the next north east meet at night so we can show them off!!
    Talking about that when are we going to organise the next one for??
    It was nearly a year ago when we had the first when we all went karting!
  30. antsS3
    antsS3 New Member
    24
    Hi Cage.
    Would also like a set of these sidelight, have PM'd a couple of times but PC is awful and it may not be sending thru...
    Ant
  31. AL_B
    AL_B Well-Known Member Team Daytona Audi S3 DSG
    1,775
    215
    I bought some 4 LED side light bulbs from UltraLED's quite a while ago. I have just got round to fitting them to my S3 this morning.
    It took bloody ages. My fingers are killing me. It took real faith in removing the bulb holders - by gripping the wires and giving them a firm tug. I tried to be gentle at first, with gradual force, but they just wouldn't budge. A firm tug is the technique. /ubbthreads/images/graemlins/wink.gif
    Anyway, took load of pics, so will post them if I remember.
    Also had "fun" today fitting Philips "Power 2 Night H7 GT-150" bulbs to my girlfriends Golf Gti Anniversary. What a nightmare!! Look good though. Just judging them in the daylight (dull and overcast) the light looks much whiter. They are supposed to have a blue tint too, but I expect thats only noticable at night.
    AL
  32. AL_B
    1,775
    215
    Here are some pics of my 4 LED ones. These are just pure white LED's, but give of a significantly noticeable blue/purple tint - not sure if I like it.
    Also, not sure if they give of as much light as the normal bulb. Either that or the lense isn't able to reflect the light out like it can with the standard bulbs.
    The following pics are on a dull day. Will do some night-time shots one day this week.
  33. AL_B
    1,775
    215
  34. DavidR
    DavidR Active Member
    1,296
    Much the same as mine Al.
    Not a lot of light, mostly blue although white leds??
  35. AL_B
    1,775
    215
  36. AL_B
    1,775
    215
  37. AL_B
    1,775
    215
  38. AL_B
    1,775
    215
  39. Andy101
    Andy101 Active Member Team Ibis Audi A6 Audi Avant Owner Group Black Edition
    249
    44
    Guys, I've recently tried some LED's in a 2004 A4 TDi, but unfortunately they flash on and off and are not constant. Has anyone else had this problem?
