LED Sidelight wedge bulb
SteveTDCi Aug 11, 2009
  1. SteveTDCi
    SteveTDCi Active Member
    1,400
    Has anyone found a suitable LED sidelight that fits in the normal holder, I want to upgrade the sidelights so they match the xenons but don't want the bulb blown lights warning to keep showing.
  2. Boydie
    Boydie Boycie VCDS Map User
    3,207
    314
    I used a company on ebay - they supplied a blue bulb which lastest ages but they did eventually pop!
    I will try find the link for you - think you need bulb number 501
  3. fsi2.0
    fsi2.0 New Member
  4. Lee_R
    Lee_R Active Member
    2,499
    12
    I bougth a set of those exact ones, tried to fit them yesterday. They dont work in my A3, shows the bulb has blown on the DIS. They wont even turn on. When removing them from the headlight one also fell out of the bulb holder so i now have one rolling about inide my headlight housing!
    I'm seriously miffed because now i have to take the bumper off to get the headlight out to fish out the rogue bulb!
    I tried the other in my Lupo though and they look great in that! :)
  5. Scott
    Scott Well-Known Member
    1,306
    126
  6. Scott
    1,306
    126
    you'll need one or two 150 ohm resistors then mate, not sure where you'd wire them up but there must be somewhere you could solder them on the back of the headlight? I'd imagine there's a guide on here somewhere....
  7. gixxer600k4
    gixxer600k4 Member
    692
    i have the LED side lights and they work fine, but i am also running them DRL s6 LED off of the side lights so its got enough resistance to work. but regarding the loose bulb in ur headlight. get a wire coat hanger through the H7 bulb socket and try to drag the bulb to the back, there is a small gap at the bottom, it happened to me and thats how i got it out!
  8. Nutkin
    Nutkin Member
    830
    im assuming i can just solder a resistor in parralel on the bulb? 150ohm definitley work?
  9. fsi2.0
    fsi2.0 New Member
    i got some 150 ohm resistors from maplins the other day, still yet to try it tho. read that a3/s3 led bulb how to guide
  10. Nutkin
    Nutkin Member
    830
    cool cool, ill just steal some from work :sly:
  11. Scott
    1,306
    126
    I'd imagine so but if 150 doesn't work then I'd guess at 120.
    Are you Nutkin from CCUK? :nunu:
  12. fsi2.0
    fsi2.0 New Member
    Does anybody know where the best place to solder in the resistors for the LED sidelights? or is soldering it to the bulb the only option? :sign_pics:
  13. Scott
    1,306
    126
    I'm not sure but I don't imagine soldering it to the bulb is the best option - you'll likely melt the LED bulb
  14. fsi2.0
    fsi2.0 New Member
  15. gixxer600k4
    gixxer600k4 Member
    692
    i think the ones like those get extremly hot! i used used some, similar to that but like a big white block, and there got very very hot. i used 330 Ohm resistors on my interior and number plate light, but i had to use more than one on some of them!
  16. Gryphon001
    Gryphon001 Active Member
    303
    44
    That my friend is a bit of an understatement... lol. I used them inside my hatch to work with the LED number plate lights... recently one blew and I had to replace it. Well after about 6+ months the resistor wasn't gold anymore. It burned off the colour from the casing, came out looking nice and silver. I tried the ones which are wrapped in shrink tubing too. The tubing says it is designed to resist up to 125C... the tubing melted.
    I am going to try to install the small 2W 150 ohm ones with each bulb now... as soon as they arrive from Hong Kong. Isn't eBay great...:)
  17. nvc
    nvc Member
    45
    just had bad experience from the ultraleds,
    bought a few bulbs on the 30th Nov, nothing turned up ( today is 11th Dec) contacted them a few times, just got ignored
    worst shopping experience for many many years. ( I buy 100+ of stuff online every year )
    :mad:
  18. 8utters
    8utters New Member
    24
    ..yup, my experience of customer service from UltraLEDS is **** too, I sent some faulty bulbs back from my TT for refund, they gave me a credit note. Whenever I tried to use the credit note it didn't work, contact eventually just got ignored, won't use them again!
  19. lake_m
    lake_m Soon to be S3'd up.
    62
  20. nvc
    nvc Member
    45
    exactly, unbelievable they can get away with a credit note,
    I have contacted my credit card company, will get full refund back.
    credit card is always handy when things went wrong
    there is nothing you can do with rogue website, buying on ebay. you can leave a feedback ( ebay is a rogue website as well)
  21. jamessg1962
    jamessg1962 Member
    123
