LED Side Lights
p9lad Jan 5, 2008
  1. p9lad
    p9lad Member
    99
    hi Guys,
    Hopefully someone can help me. I bought some Ignition LED Sidelights a few days ago. Installed them no problem worked for like 20 minutes and then i got a Warnign on my DIS saying bulb had gone! Went to check the light and it was out!
    Any way round this? Should i buy a resistor? I saw on HIDs4u.co.uk you can buy a pair of resistors for a £5 but b4 i do that wanted to check if there was a work around?
    Cheers!
    P9LAD
  2. redbutcher
    redbutcher Member
    649
    You'll need resistors to get them working properly. Have a search through the forum as pretty certain this has been discussed before.
  3. RGBArgee
    RGBArgee Guest
    What's the point of LED sidelights? I am genuinely intrigued. I know Audi are introducing on new models but why bother retro fitting, everyone knows they are not standard fit?:icon_thumright:
  4. Issac Hunt
    1,162
    I guess he means changing the bulb for an LED one as opposed to fitting LED lights light the A5/S6 etc?
    Some people like the look of the LED bulb, a bit closer to the light color of the Xenom headlight.
    Not my cup of tea I must admit but each to their own!
    BTW a resistor will defintley be required to turn off the blown bulb indicator in the DIS.
  5. RGBArgee
    RGBArgee Guest
    Ta for clarification... but IMHO what's the point?
    R:icon_thumright:
  6. Issac Hunt
    1,162
    Havent a clue but like I say some folk like it as it gives a closer colour to that of Xenons. I couldnt be ***** to fit them to mine but each to their own I guess.
    If we were all the same the world would be a grim place!
  7. RGBArgee
    RGBArgee Guest
    Agreed we would all be brain washed into buying BMW's with PP's !!
    Black Standard Quick Audis are best IMHO!
  8. p9lad
    p9lad Member
    99
    hi guys, well basically i noticed the light is a lot brighter then the normal sidelights i already have. also like previous members have said it is more of a Xenon look. A friend of mine who does all car electricals audio, alarms and what not has got soem resitors so will fit them in on wednesday!
    On a side note just fitted Ignition HID Kit to the car! Works brilliantly! No alarms, Wiper motor has not blown up yet and the light is brilliant!:hubbahubba:
  9. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    You can say that again! (Oh wait, you do - a lot!)
