LED reversing lights
ScottD3 Mar 25, 2012
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    Nothing amazing but they are better than the incandescent bulbs, the like is white, which you'd expect from LEDs and they are brighter, which makes it a bit better for reversing at night.
    Well, I've had 1 fitted for about a week and when parking at night I can see the difference between the two different bulbs.
    I bought them from T8ups.
    I got no errors but I'm not sure if the bulb warning system works on reversion lights.
    any here, here's some pics.
    I used the same camera settings on each image to make the comparison easier.
    Old
    New
    Combined.
    All new.
  2. Foxmeister
    Foxmeister Fired Up!
    1,785
    I started doing this on mine bout a year ago......still aint got round to finishing it yet! lol
    What LED's did he supply for it? IS it the type that are fitted into a standard bulb fitting? Im doing mine free style!
  3. ScottD3
    15,165
    1,124
    yeah, its 4 boards with LEDs on both sides, fitted in to a standard bulb fitting.
    Free style?
    Poke the LEDs and cables through the hole and let them dangle? :ninja:
  4. audiv8quattro
    audiv8quattro Member
    443
    9
    Mmmmmmmmmm toffee popcorn lol, looks good mate
  5. Foxmeister
    1,785
    Not quite.
    As you know, i used custom clear tail lights and as such when i went for the facelift red tint, i had to do the reverse section red aswell to get the look i wanted, so if i were to use normal position reverse bulbs it would end up pink!:drag:
    So to combat this, the only clear section i have is the indicator piece, so i was wiring in 2 or 3 standard single LED's on each side, then would drill them in under the indicator bulb and fit them with the little plastic collar to set them in like so
