LED REVERSE lights...
H88 May 14, 2012
  1. H88
    H88 Member
    244
  2. audicruiser
    audicruiser Audi Heaven
    1,865
    Would of thought they will throw up an error so resistor would be required, plus because the LEDs face straight out they won't utilise the reflector in the light cluster and so will be no brighter, in fact probably worse.
  3. mike foster
    3,967
    As audicruiser says, they won't work properly in the reflector and would need a resistor, but in any case reversing lights aren't on the car for the driver to see at the back - they are there to warn other motorists and pedestrians that the vehicle is reversing !
    If you want to see backwards then get a camera installed.
  4. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    Talk to T8ups on here about LED lights.
    He's supplied many kits to people with out any errors.
    I bought a set of LED reversing lights for my B5 off him some time ago and really like them.
    I was out testing a LED light I made over the weekend and thought I'd test the reversing lights as well.
    Here's some pics.
  5. L1ARR
    L1ARR Active Member
    424
    43
    Another Reversing light question.
    My S3 only has 1 reversing light on the left, its a SP3 facelift. Should i have 2?
  6. audicruiser
    1,865
    If it's a three door then no, if it's a Sportback then you should have two. On the three door, the near side has the reversing light and the off side has the fog light.
  7. quattro81
    quattro81 All the gear.. No idea
    970
    90
    Soo... Maybe a stupid question, but does the SB have two fogs at the rear as well, or just the one?
  8. H88
    H88 Member
    244
    Ok thanks people,I will contact t8ups for some led lights :))
  9. mike foster
    3,967
    Two !
  10. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,027
    729
    the 8P3's will bring up errors when installing LED's outside at the rear, i have already tried doing the reverse lights in the SB and they are 501.
    the 8P1 and 8P2 will be fine, i am getting a delivery of bright LED's in and they will fit the DRL's and the Reverse lights.
    Trups
  11. L1ARR
    L1ARR Active Member
    424
    43
    Thanks Cruiser,
    Wasn't too sure if it was my car with a blown bulb
  12. Ash187
    7,478
    735
    Trups mate, text me when you get the reverse LEDs in, I want a set for my SB
  13. t8ups
    2,027
    729
    Will Do Ash.
  14. Helifella
    Helifella Co-Driver ~ Hattie Staff Member Moderator Regional Rep VCDS Map User
    569
    149
    43
    +1 mate :)
  15. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    221
    I'm waiting for the day for some LED brake and indicators for my 2012... :(
  16. mike foster
    3,967
    You've already got one LED brake - how many do you need ? !lol
  17. Cruiser89
    1,484
    221
    I don't have any LEDs in the rear clusters. I have a 3dr. Unless you mean the high vis brake?
    Only ones I have are in the number plate.
  18. mike foster
    3,967
    Yeah - I mean the high level one !
  19. minty86
    minty86 New Member
    Feels little bit stupid but does anybody know how to take out the reverse light bulb on Audi A3 1.6 TDI 2010 S-Line 8P?
    Anybody got link, please put them here. Thanks.
  20. Chris Eaton
    Chris Eaton Member
    85
    25
  21. nicks260
    nicks260 Member
    31
    13
    does anyone know if you can get led reverse bulbs for s3 8v?? I've bought two sets off eBay both claiming they're the car and they don't. i know its bayonet fitting but the bulbs were too big. any ideas?? also want to try and get daytime running lights where the fog lights would go if anyone has any ideas?
  22. dp_motley
    dp_motley 2012 A3 1.6 TDI
    303
    65
    Let me bump this tread. I'm in exactly same situation as the OP. My reverse light halogen bulbs are too dark. The original halogens are w16w type, 15mm x 35mm. I'm looking at these: http://www.ebay.co.uk/itm/162120399635 Is 800lm much brighter then the OE halogen bulbs? Anyone has experience with the LED reverse light like this?
  23. Marler1337
    Marler1337 New Member
    I bought this the other day: http://www.ebay.co.uk/itm/162059964279?_trksid=p2060353.m2749.l2648&ssPageName=STRK:MEBIDX:IT it's a lot brighter then the standard one. Only issue I've had is with my headunit and reverse camera it didn't work 100%. There was a hum from the headunit and the camera image started moving up and down the screen so for now I've put the previous standard bulb back in. I'd recommend giving those ones a try if you don't have a reverse camera.
  24. Gazwould
    Gazwould Well-Known Member
    4,783
    1,924
  25. dp_motley
    303
    65
    I'm afraid the 50W and 80W bulbs you linked to won't fit my car. I bought the LEDs from my link. I don't have a camera yet, but it's arriving this week together with an Android head unit. I don't plan to retrofitting it until spring though.
  26. tcardio
    tcardio Well-Known Member
    967
    277
    trups is great but another alternative is deAutokey
  27. dp_motley
    303
    65
    Fitted the LED reverse lights from my link above. I fitted the left one first and took a picture for side-by-side comparison of LED vs OEM.
  28. SootySport
    SootySport Well-Known Member Team Silver
    2,713
    721
    Woooooo! I've gone blind.
    dp_motley likes this.
  29. dp_motley
    303
    65
    Lol. And that was one LED only. I fitted the second one today. Take sunglasses on :blacksunrays:
  30. The Governor
    The Governor Active Member
    527
    75
    Was this the bulb you fitted mate, it is a wedge connector not a bayonet type then?
    Does anyone know if these are good for a 2011 3 Door 8P, I spoke to Trups and he was saying there can be issues with errors on theM?
  31. downtothebone
    downtothebone Active Member Team Scuba Audi A3 Audi Cabriolet Owner Group S-line owners group
    607
    104
    43
    I bought similar pair (wedge as shown) having tried a number of different types and they work on my 2011. It's only been a week but no errors or flickering so far.
  32. dp_motley
    303
    65
    I bought from this seller http://www.ebay.co.uk/itm/162120399635 . No errors at all. To check compatibility, simply look at your original bulb.
  33. Dannymoto
    Dannymoto Active Member TeamMisano Audi A3 Black Edition
    502
    79
  34. The Governor
    527
    75
    Thanks mate, so in your car they have a wedge connector then? I'd have to assume all 2011 models have a wedge then surely (rhetorical question!)
  35. maxpayne
    maxpayne Active Member
    173
    31
    Just fitted mine with cheap LEDs from eBay and they are a visible step up from the jaded yellow built in ones. Mine is an 8PA 2005 and takes the wedge shaped ones. Already contemplating upgrading everything to LED now that I've seen the results first hand!
    Ben85 likes this.
  36. Ben85
    Ben85 Active Member Audi A3 TDi Manual
    157
    70
    You got a link?
    maxpayne likes this.
  37. maxpayne
    173
    31
    I got these: http://www.ebay.co.uk/itm/201750355380
    Please note that they look very bright, but I wouldn't depend on them to light up the back of the car for visibility. You'll probably be better off getting CREE types LEDs (as posted earlier in the thread) like these: http://www.ebay.co.uk/itm/2x-50W-PU...BUS-ERROR-FREE-DRL-REVERSE-LIGHT/251393153607 for that.
    Another member here @t8ups also sells reverse LEDs, which is another option.
    Good luck!
  38. maxpayne
    173
    31
    Here's the updated photo. For some reason the photo link in my earlier post didn't work
  39. nates
    nates New Member
    23
    Are these really worth the bother? I find these generally appear excessively bright and fail after a few months - similar to the numberplate leds.
  40. maxpayne
    173
    31
    I just decided to take the risk. They do come with warranty and in theory LEDs are supposed to be long lasting. Only time will tell. Kept the old bulbs as backups anyway
