LED replacement for DRL?
razza1 Mar 11, 2011
  1. razza1
    razza1 Well-Known Member
    3,063
    820
    Hi, have the xenons with the DRL on them (single bulb, not a strip). I've upgraded my sidelights to LEDs, but these are bigger bulbs and are yellow :(
    Does anyone know if I can get LEDs to replace these with (they're not the sidelight ones)?
    Razza
  2. Richardesty
    Richardesty loves quattro
    742
    20
    Yes mate - you can in effect replace them with any ba15s type LED bulb.
    However, you will need to fit a pair of load resistors with most types to meet the needs of canbuc and be aware that different bulbs can look quite different within the lens. I find those with SMD bulbs are best.
    These suggest you don't need resistors Canbus white 27 SMD LED BA15s 1156 382 bulbs
    Rich
  3. razza1
    3,063
    820
  4. gjwell
    gjwell Member
    82
    Hi razza1, Did you get anywhere with this? I really want to replace my DRL's too they are dull and yellow :(. If you go the load resistor route I assume they have to be wired in serial?
  5. razza1
    3,063
    820
    nope :( haven't got anywhere yet but pushed for time to be honest to look into further at the moment
  6. Gregzy88
    Gregzy88 A3 Newbie
    70
  7. Richardesty
    742
    20
    The PIAA 27w versions are fine heat wise, but to be honest aren't 'that' White......
  8. ultramodz
    ultramodz 06 A4 2.0T FSi S-Line SE
    515
  9. gjwell
    gjwell Member
    82
    Ok replaced the side lights, no light out warnings and they look great :). Thanks Ultramodz i've bought all the bits on your write up. Numberplate LEDs fitted with no errors :) So I have spare resistors. I fitted the DRL's one is faulty :( so need to return them to. I spent a lot of time considering locations for the resistors. I think i will make a metal bracket to screw them to the chassis somewhere and try and splice into the loom rather than scotch locks, so the light units remain watertight, but we will see. Next project I was thinking about was fitting the missing extra boot light and the door warning and puddle lights. Any P/N links to guides appreciated.
  10. razza1
    3,063
    820
  11. razza1
    3,063
    820
    getting the number plate ones as well, gjwell, hoping these don't have issues, if they do I may take those resistors off your hand...
  12. razza1
    3,063
    820
    wow, quick service, ordered the number plate ones yesterday, arrived today, just fitted, and no errors :)
  13. razza1
    3,063
    820
    Just fitted the DRL lights (5min job), more blueish than white to be honest, but better than the horrible yellow, and at £11 delivered much more value for money than the PIAAs. They also sent me a wrong bulb by mistake (2 pin contact), so sent two more bulbs. So I have a spare one pin now in case one blows :)
    Can't load photos to photobucket at work, anyone want to host it for me? PM me your email address and I'll send over.
  14. razza1
    3,063
    820
