LED Numberplate Lights staying on
sc00byd00byd00 Dec 6, 2010
  1. sc00byd00byd00
    sc00byd00byd00 Frank and Beans............... VCDS Map User
    233
    Anybody else having this issue.
    I initially thought it would just be burning up the residual charge, but checking this morning, the LED lights had been on all night.
  2. simon.m
    simon.m Active Member
    2,747
    sounds like they are shorting out mate could be the led its self or the light holder has got damp some how
  3. sc00byd00byd00
    233
  4. simon.m
    2,747
    maybe badly made ones mate or some thing you can pick them up in halfords i think about 10 pounds ish but they would be better made
  5. sc00byd00byd00
    233
    Never seen LED bulbs in HALFRAUDS ???
  6. simon.m
    2,747
    they do alot now days mate there are these ones but if you go to there web site and put in car LEDS there is loads
    Halfords | Prism LED Festoon
  7. simon.m
    2,747
  8. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
    I run the Prism Halfords jobbies too - very happy with them......
  9. MDA
    MDA sploorer
    87
    nice
    but do they mess with the bulb out warnings ?
  10. simon.m
    2,747
    would i be wrong in saying that the number plate lights are not covered by the lights out waring
  11. sc00byd00byd00
    233
    Dunno mate ?
  12. quattrojames
    14,060
    583
    You would be!
  13. simon.m
    2,747
    oh well would not be the first time lol
  14. quattrojames
    14,060
    583
    Or the last .... ;)
  15. simon.m
    2,747
    of course not james ;-) all though i dont have full DIS so i can be wrong lol
  16. CHRIS555
    1,970
    10
    The only issue is that my light bulb out warning dash light pops up but as soon as i turn the lights on this goes straight away with no issues what so ever
  17. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    my LED's are working just fine at the mo, touch wood!
  18. Xmay4444
    Xmay4444 On Point!!
    258
    I got a number plate bulb out and i aint getting no warnings.
  19. quattrojames
    14,060
    583
    Is that standard or retrofit DIS?
    I ran without my bulbs for a couple of days while I was waiting for the new bulb holder to arrive and got fed up of the warning light!
  20. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    Both need to fail for DIS to register a bulb out warning - have tested this when I did the Reverse Camera mod.
    FYI: License plate lights are wired in parallel so the DIS sees both bulbs as one.
  21. sc00byd00byd00
    233
    Any idea's Woodlord why my lights are staying on when ignition and lights are turned off ? Is there a current passing round this electrical wiring, all be it a very small one that is the reason the lights are staying on (but dim)
    An idea the ebay seller suggested would be to get some slightly more expensive ones that have a load resistor built into them (i.e. no error ones) to only light up when they get the voltage required that would normally light up the standard filament bulbs ?
    Does that sound about right ?
    If so, i'm contemplating one of the following ?
    ERROR FREE 3SMD CANBUS 38mm 272 LED FESTOON BULB on eBay (end time 09-Dec-10 15:44:55 GMT)
    239 C5W 272 Dome 36mm LED Festoon no canbus error free on eBay (end time 22-Dec-10 09:12:50 GMT)
    However, there are a few other issues with the wiring on mine that may need replacing pending expert opinion if this is contributary to the cause of the lights staying on ??
  22. Woorlord
    951
    17
    An LED only requires 20mA of current to illuminate at a reasonable light level so I guess if there is leakage in the driver circuit to the LED then it is possible they will illuminate very dimly if the driver circuit does not have enough proper load drain to switch off.
    Putting a shunt resistor in parallel to the LED's should suck any residual current out of the driver circuit and probably make the circuit switch off properly. A simpler "test" method would be to solder some wires to a working number plate bulb and attach this to the license plate terminals (hide it around the back somewhere taped up) - this will fool the driver circuit in working properly and your LED's should go out when the lights switched off. One bulb should be sufficient. If this works OK we can then get a power resistor to take the place of the bulb for a more permanent solution.
  23. quattro tony
    quattro tony Member
    167
    Strange that one. Ive got some led lamps on mine and they work 100% fine. The only thing i can think of is i had a a3 in the past that the battery kept going flat and eventually i traced it to a faulty light switch which was somehow just putting the number plate lamps all the time engine off and running and draining the battery. I would put a multimeter between the terminals and see what voltage you are getting there and maybe swapping the bulbs back to std just to eliminate a bulb fault.
  24. Woorlord
    951
    17
    If you measure the in-line current (DVM to Amps or mA) this will give a better indication of what the battery current drain is through the number plate lights. Voltage is not really an issue!
  25. sc00byd00byd00
    233
    Ok.... say that again in laymans terms........ I'm not very technical when it comes to stuff like this.
    Not really into fiddling like that if i'm honest, prefer the plug and play improvments.
    Can I not just buy a LED bulb that had all that electronic gubbins already incorporated into it ? Not really bothered if it costs more
