LED Number Plate Unit Conversion
Discussion in 'A3/S3/Sportback (8P Chassis)' started by david_phillips95, Dec 21, 2009.
  1. Scott
    Scott Well-Known Member
    Mar 10, 2009
    1,296
    123
    For what it's worth I have been running mine for a few months (maybe 4-5+)
    See up for which bulbs I'm using
  2. Advert Guest Advertisement
  3. a3_dan
    a3_dan Member
    Aug 1, 2009
    588
    I just bought myself a set from the convert2xenon site. The same as N8 etc has. I will post pics to show what they look like when they arrive and have fitted them.
  4. N8
    N8 Kowalski Details
    Jul 4, 2007
    17,172
    718
    No problems, running them for about 4 months, no problems.
    No fault codes and they've been great.
    Nice one Dan. :thumbsup:
  5. Splathead
    Splathead Active Member
    Team Estoril VCDS Map User Audi S3
    Dec 17, 2007
    237
    80
  6. a3_dan
    a3_dan Member
    Aug 1, 2009
    588
  7. a3_dan
    a3_dan Member
    Aug 1, 2009
    588
    Right people,
    Received my LED number plate lights couple days after ordered them, fitted them today and they look the nuts i must say, BUT, after using my car today a few times, i have now started to get the error on my DIS....WHYYYYYYY!!!?? Why would it work fine with no errors all day and then throw up a hissy fit? Whilst the error occurs, if i switch the ignition off and on again, the lights will switch back on, but the error will remain.... What can I do?
    Thanks, Dan
  8. jb0o
    jb0o North East Forum Moderator
    Site Sponsor Regional Rep VCDS Map User
    Feb 2, 2009
    2,661
    115
    Not sure if the resistors would play a part in this problem but have you checked them?
  9. a3_dan
    a3_dan Member
    Aug 1, 2009
    588
    I havnt yet, bit late now so cant be arsed with it. Will take a look tomoz. However these little festoon style led replacements already have the correct resistance fitted, apparently!
  10. david_phillips95
    Nov 25, 2008
    536
    Looks like these "perfect" bulbs arent as perfect as various people have made out :lmfao: i can confirm my lights are running perfectly with no problems, +1 to my UFO beams :laugh:
  11. a3_dan
    a3_dan Member
    Aug 1, 2009
    588
    hahaha I have been using my car today and so far no more errors...bit weird huh.
  12. ifty786786
    ifty786786 New Member
    May 31, 2009
    9
    number plate lights look nice, gonna get them on mine.
  13. Mattfaced
    Mattfaced Member
    Dec 8, 2009
    77
    I dont think i would get errors on my 97 1.8t agu with these would i?
  14. david_phillips95
    Nov 25, 2008
    536
    i dont think you would, the units im running have built in resistors to prevent errors anyways.
    One of my favourite mods so far :)
  15. david_phillips95
    Nov 25, 2008
    536
  16. kkp0897
    kkp0897 Active Member
    Sep 4, 2009
    751
    41
    Dave - useful post Thanks. Any problems a month on?
    I am interested in changing mine also for the Festoons...
    N8 mate, did you ever get any pics uploaded showing yours off?
    Don't other Audi Models have OEM Led Rear Number Plate Lights which would fit?
    KKP
    #55 kkp0897, Jan 30, 2010
  17. david_phillips95
    Nov 25, 2008
    536
    Not a single issue mate, i knew as soon as i opened the box they would be perfect. They are really well made, yeah there expensive but you get what you pay for. After reading about people wiring in resistors etc i went off the idea of just changing the bulb, also the lens of the OEM bulb holder is not designed for LED bulbs so does not transmit the light as well as these do.
    N8 has yet to post pictures of his setup that is "perfect" lol :)
  18. smythey1
    smythey1 Member
    Dec 25, 2009
    175
  19. PH1L
    PH1L Gievf Buckets
    Jan 8, 2010
    3,864
    40
    i have heatsunk led bulbs in mine produces the same light with no errors, ive been toying with the idea of getting these but at £35 a set im reluctant perhaps a group buy?
  20. kkp0897
    Sep 4, 2009
    751
    41
  21. PH1L
    PH1L Gievf Buckets
    Jan 8, 2010
    3,864
    40
    they will be about the same light output as your origional halogens but will be a nice colour ive put a set in my rear convenience lighting, looks like they will bring on a bulb error too
  22. Advert Guest Advertisement
    to hide this advert.
  23. Pii
    Pii Member
    Jan 21, 2010
    748
    Such a simple thing and yet looks so good!
  24. I'mRonBurgundy?
    I'mRonBurgundy? Lets make that kitten purr...
    Jan 29, 2008
    554
  25. Splathead
    Dec 17, 2007
    237
    80
    Yep, no problems with mine.
  26. a3_dan
    a3_dan Member
    Aug 1, 2009
    588
    I have these mate, and i too get errors, on my 55 plate a3. I spoke to the company and they offered a refund, but just cant be arsed at mo to take them back out. Its weird, i only get errors on the dash whens its wet outside....why do you think that is?
    Dan
  27. I'mRonBurgundy?
    Jan 29, 2008
    554
    No idea.
    Mine don't even seem to work! Swapped the passenger side and tested fine but when I swapped the drivers-side neither worked and I got the bulb error too.
  28. kkp0897
    Sep 4, 2009
    751
    41
    Pardon my ignorance, what happens if you put the original ones back in? Does the error disappear or is it a Vagcom to reset the error? I'm interested also, Number plates, puddle lights, interior lights.. the full monty basically but approaching this change with caution.
    Cheers, KKP
  29. I'mRonBurgundy?
    Jan 29, 2008
    554
    All back to normal with the originals in - no errors and both bulbs working.
    Most seem to get no error or just the error, due to the voltage drop, but I'm experiencing the bulbs not working at all. Might be a duff bulb I guess so will have another go next weekend.
  30. PH1L
    PH1L Gievf Buckets
    Jan 8, 2010
    3,864
    40
    did you try them the opposite way round?, leds are polarity sensitive
  31. a3_dan
    a3_dan Member
    Aug 1, 2009
    588
    Drop them an email mate and they will offer a refund if you send them back. I cant be bothered at mo, Its a shame, because they do work I would say 90% of the time, and they look the absolute nuts. But I think soon I will have to go for the other more expensive bulbs some of the guys here have got from ebay, although I think they do look way too overkill and bright for my liking...Better than OEM i guess though.
    If only I could find out why I only seem to get an error on the dash when its damp/wet out.....
  32. I'mRonBurgundy?
    Jan 29, 2008
    554
    Yeah I remembered that after I put the first one in and nothing happend.
  33. glasgowdubber
    glasgowdubber Active Member
    Feb 24, 2010
    323
    53
    Cheers for this, ordered mines last night so should have them this week.
    Will take pics and post up any problems if/when they arrise
  34. glasgowdubber
    Feb 24, 2010
    323
    53
    LED's came today guys, just home will be fitted later on and will post some pics up :)
  35. kkp0897
    Sep 4, 2009
    751
    41
    How's the LEDs? Did you get them fitted?
  36. V16
    V16 Member
    Jan 20, 2010
    214
    Finally got some leds without the canbus error, cost me around £16, there not as blue as the pic but it looks great at night!
    can't find the link where i bought them from but will post it as soon as i do.
  37. luke1987
    luke1987 Air Ride is for Ballers!!
    Mar 14, 2009
    612
    73
    i bought the ones of convert to xenon website, the same as N8 and they work but this morning on 2 occasions they went out and the dash said the number plate light was out, i turned them off and back on and it cleared. anyone else had similar thing happen to them??
  38. a3_dan
    a3_dan Member
    Aug 1, 2009
    588
    I get the same mate. I bought the same set.
    I emailed them a while back and they said they are now aware they do not work on 05 and 55 plates (im a 55). They offered a refund if I sent them back, but I cant be arsed with it, so just grin and bear them at moment. They dont go out that often for me to get stressed with it.
  39. mdre83
    mdre83 Member
    Aug 25, 2007
    634
    These are mine...got them from ebay...resistor in each side and no errors, touch wood.
  40. Pii
    Pii Member
    Jan 21, 2010
    748
    Convert2xenon Support emailed me the following::crying:
    Dear Sir,
    These bulbs work an all vehicles except Audi A3, A4, A6 and A8 after 2005-.
    Unfortunately at the moment we do not have suitable product for your vehicle.
    Very polite and truthful response so hats off to them. Thought I'd share this info to the time/money of other members.
    Might have to take the plunge on te ebay route..... but 40 quid just seems a little pricey! :motz:
    #78 Pii, Apr 19, 2010
  41. luke1987
    Mar 14, 2009
    612
    73
    I might just solder a low ohm resistor in, can't do any harm I wouldn't have thought .
  42. a3_dan
    a3_dan Member
    Aug 1, 2009
    588
    let me know how that goes and I will give it a go.
