LED lights??
[Dave B] Sep 27, 2004
  1. [Dave B]
    [Dave B] Daddy
    2,027
    145
    There was a post on LED lights on here a while back but I am having trouble finding it? I am looking to buy some but can't find any details? /ubbthreads/images/graemlins/confused.gif
  2. nervus
    nervus Well-Known Member
    1,370
    121
    What you after - soft interior lighting?
  3. imported_Yaseen
    imported_Yaseen Guest
  4. Gambba
    Gambba Active Member
    1,361
    Try a search on Prism, they're one of the RING brands and in my opinion good quality.
    Drill has been using some in his A3 and had them fail, but now using mine for almost a year they've not had anything go wrong.
    The above is unbiased as I didn't pay for them as I got them for 'Test' purposes from Ring.......unrelated directly to cars /ubbthreads/images/graemlins/beerchug.gif
  5. t30gue
    t30gue Member
    47
    I am on my second set from ultraleds.co.uk They are standard 6 bulb white led's, and look awesome! they don't last long though.
    I am now looking to try another brand.
    Any suggestions anyone?
    Chris.
  6. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Many thanks guys, anyone know which ones would suit a pre-facelift A3? /ubbthreads/images/graemlins/confused.gif
  7. RichA3Turbo
    5,089
    need '501' type sidelight bulbs!
    Rich
  8. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Thanks Rich, one pair now ordered! /ubbthreads/images/graemlins/cool.gif
  9. Stepho
    Stepho Member
    444
    [ QUOTE ]
    [/ QUOTE ]
    Chris
    I bought the PIAA LED's (one white/one blue per side) only problem I had was removing the old sidelight bulbs. I have tried various methods but they won't budge. How did you remove yours?
    Steph /ubbthreads/images/graemlins/beerchug.gif
  10. t30gue
    t30gue Member
    47
    Get a missus with very small hands! /ubbthreads/images/graemlins/lol.gif
    I found the Drivers side lamp a bit easier, open the rear cover and push it back as far as it will go. then squeeze your fingers in. I found looking in through the front of the h/lamp helps to guide me to the correct wires/bulbholder, as you can see it moving when your hand is on it. Pull this out and carefully pull bulb from holder and replace. Getting it all back is a little tricky. Turning the sidelights on a this point helps to guide the new bulb into the hole in the headlamp (again look from front)Then push firmly home. Passenger side is made more awkward by less available space, but I usually manage to pull the bulb out carefully by its wires (I know I shouldn't, but I'm not moving the battery for a poxy sidelight) Again replace the bulb. At this point I just manage to push it all back with the end of my finger, as whole hand will not fit in space. Hurts a bit though, but worth it in the end. Should take about 10 mins all in.
    Good luck
    Chris. /ubbthreads/images/graemlins/beerchug.gif
  11. Stepho
    Stepho Member
    444
    Cheers for that Chris. I will give it a go tonight when I finish. Time permitted as its a footie night. /ubbthreads/images/graemlins/smile_smoking.gif
  12. antsS3
    antsS3 New Member
    24
    Hi all!
    Read this post a little too late! I have two spare type 501 bulbs (4 LED and Blue) that fit in the door side and puddle lights if anyone wants them. They're £6 including postage. PM me if you're interested. I have the white LEDS in the boot and as my rear plate lights which are cool. Inside, have the very bright 9-LED versions that really give the car a soft blue glow at night when opening the car.
    Cheers,
    Anthony
  13. [Dave B]
    [Dave B] Daddy
    2,027
    145
    [ QUOTE ]
    antsS3 said:
    Hi all!
    Cheers,
    Anthony
    [/ QUOTE ]
    Hadn't thought of those applications, might have to buy some more now!
