LED Indicators
t8ups May 29, 2016
  1. Jakes2514
    Jakes2514 A6 C7 AllRoad 3.0 TDI - Ibis White Gold Supporter quattro Audi A6 Audi Avant Owner Group TDi
    122
    92
    Interestingly I have a A6C7 Allroad (65 reg) and it looks like different light bulbs are used than the C7 above:
    My lights are the Xeons that look like:
    And the bulb that came out is the one on the left with the supplied LED from Trups on the right (he is aware and will be exchanging mine)
    Just thought id post this here for general awareness.
  2. GjrBartlett
    GjrBartlett Active Member Bronze Supporter Team Silver Audi A4 Audi Avant Owner Group S-line owners group TDi Manual
    460
    141
    43
    Just PM'd you mate, mine (2 sets) both need changing.
    Cheers, Gareth.
  3. GjrBartlett
    460
    141
    43
    Evening,
    With Trups kind permission I have a set of these LED indicators to sell on, bought them in the original group buy for a friend, however he's selling up, so I have no need for them.
    They were bought for a Pre-FL B8, Trups has kindly swapped them for the shorter pin version, given the issues a few people have had fitting them. (See back a few posts on this thread).
    Looking to re-coup what I paid for them which was £21 & I'll post them for free.
    Please PM me if interested.
    Regards, Gaz.
  4. GjrBartlett
    460
    141
    43
    SOLD
  5. NL316
    NL316 Active Member TFSI Owners Group Team Silver Audi A4 saloon Manual
    167
    114
    43
    Hello mate,
    Was the vid useful? Did you managed to get your's fitted?
    GjrBartlett likes this.
  6. GjrBartlett
    460
    141
    43
    Sorry mate, should have messaged you early to thank you, the Vid was a real help.
    Had a few issues fitting, partly due to large hands (thankfully got a work colleague to assist) & then a ever so slightly bent pin which ended up pushing the internals out of the LED, thanks fully T8ups (Top bloke) has agreed to sort & a replacement is in the post.
    Looks a little weird with only one LED fitted at the moment, but does allow me to appreciate the difference every time I unlock/lock the car.
    Sandra and NL316 like this.
  7. NL316
    167
    114
    43
    LoL yeh the hands bit was a pain. At least you're getting it sorted.
  8. ruairi83
    ruairi83 Well-Known Member Team Sepang quattro Audi A4 Black Edition
    1,707
    557
    Anyone interested in these I have a brand new set for b8.5 a4
    Or a5.
    £21 posted
  9. Turbo Tony
    Turbo Tony Member
    43
    24
    Trups, do you have a set of these that would fit a 2008 D3 S8? If so, there's also a few interior LEDs I'd like to get at the same time.
  10. dimitar.tuntov.5
    dimitar.tuntov.5 Well-Known Member
    1,082
    453
    are they error free and fitting ok in A4 B7 ?
  11. Hanny
    Hanny New Member Team Dolphin Grey Team V6 VCDS Map User Audi A6 Audi Avant Owner Group s tronic
    29
    9
    Hey Trups - not sure if this thread is still active - if so could you tell me how much for front and rear indicator LEDs for A6 C6 Allroad (2007) - many thanks
    KrisKrk likes this.
  12. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,982
    11,139
  13. SportbackSam
    SportbackSam New Member
    10
    If this is still active, I'd like a set of those front LED indicators for my 8v S3 PFL if it matters.
  14. Dubjam
    Dubjam a bullet with butterfly wings Team Ibis VCDS Map User Audi A3 Black Edition
    498
    133
    43
    Yes 8P FL required
  15. KrisKrk
    KrisKrk A6 C6 4F 2010 LeMans Avant Audi A6 Audi Avant Owner Group S-line owners group TDi Manual Le Mans Edition
    1,686
    1,881
    I would be also interested but reading through the thread, he didn't had them yet.
  16. Sandra
    27,982
    11,139
    KrisKrk likes this.
  17. ruairi83
    1,707
    557
    Have a set of these removed from a B8.5 A4. Fit a5 also. £15 posted
    PM if interested
  18. Booboo
    Booboo Member Team Daytona TFSI Owners Group quattro Audi A4 Black Edition s tronic S-line owners group
    139
    24
    I've just fitted some & found it a lot easier to remove the top of the air box & then pull out he bottom from it's rubber bung supports so the air box is completely removed. Then you can lean over and see in to the back of the headlight.
  19. CountryGent
    CountryGent Member TFSI Owners Group Team Brilliant Black Audi S1 quattro Audi A4 Audi Avant Owner Group S-line owners group Manual
    51
    Hi t8ups,
    I have an '06 A4 B7 and was looking to change to LEDs as a number of the external light bulbs will need replacing. Are there sets for rear lamps, brake, side lights, reverse and indicator? Is this a practical upgrade to bother with as I watched the vid you posted for B8 A4, B8 A5 facelift only, A3 8V with the xenons or halogens. The difference was a real improvement. Is there a need for coding or error resetting if the standard bolbs are replaced?
  20. JAAC UK
    JAAC UK Member Audi S4
    70
    14
    im intrested if you do the group buy again b8 s4
  21. ch1z64
    ch1z64 C'mon you's bhoy's in Green TFSI Owners Group Silver Supporter Team Sprint Audi S3 Manual
    1,086
    164
    jg51-Aud A5
    2. Chez A5
    3. Ruairi183- A4
    4. Scuba3 - A5
    5. Chris100 - S3 Saloon 8V
    6. Michael Parker - S3 Facelift
    7. Michael Parker FriendS3 Facelift
    8. GjrBartlett - B8 A4
    9. Exspartan36 - B8 A4
    10. Silvester_t - S3 Facelift
    11.C39KER - A3 8V 2015
    12. JulianW - A5 FL
    13. Raffhussain - S3 Facelift
    14. JDH - A5 FL
    15. JDH - A5 FL #2
    16. Mr.G - 8V
    17.Pete84 - A5 FL
    18. JoJo - C7 A6 2012
    19. Craig-P - 2009 S3 Facelift
    20. WattzyA5 - Aud A5 FL
    21. Scott.T A5 FL.
    22. Jaz - Passat CC 2012 (white) (via Email)
    23. Lenny151 - 8V
    24. CoolAsIce - 8P Facelift
    25. kkp0897 - 8P S3 Facelift
    26. Rabie2412 - 2012 A6
    27. Adam Russel - A4 B8 2011
    28. PB2.7TDI - A4 B8
    29. D1309 - S3 8V
    30. Callum4545 - S3 8P 2011
    31. Chris90 - A4 B8.5 2012 onwards
    32. GjrBartlett (Friend - B8 A4)
    33. MikeParkin - S3 8V
    34. S11M - A3 8P facelift
    35. Geebo A5
    36. Jelhead A3 8V
    37. Oliver Fish S3 8V
    38. MGrove03 - A3 8V
    39. Mike Price - 8v ?
    40. GAS MONKEY A4 B8.5
    41.Ch1z64 S3 59 plate
  22. Tom Shields
    Tom Shields Member TeamMisano TFSI Owners Group VCDS Map User Audi A3
    78
    9
    jg51-Aud A5
    2. Chez A5
    3. Ruairi183- A4
    4. Scuba3 - A5
    12. JulianW - A5 FL
    14. JDH - A5 FL
    15. JDH - A5 FL #2
    16. Mr.G - 8V
    17.Pete84 - A5 FL
    21. Scott.T A5 FL.
    23. Lenny151 - 8V
    29. D1309 - S3 8V
    35. Geebo A5
    36. Jelhead A3 8V
    42. Tom Shields A3 8V 2013
  23. ruairi83
    1,707
    557
    This group by is over lads lol
    t8ups and jojo like this.
  24. Tom Shields
    78
    9
    Dang it!
  25. ruairi83
    1,707
    557
    Buy... sorry dude. Message @t8ups for a set
  26. KrisKrk
    1,686
    1,881
    Lads, check out @t8ups website emtuning.co.uk in exterior leds/indicators bulbs section.
    Been ensured that he’s supplier will be getting some new load of bulbs to him soon.
    I’m awaiting some myself for an A6 so might have new bulbs suitable for your motors also
  27. ch1z64
    1,086
    164
    last time i spoke to him he said if we could get another group buy he would sort something out .
    t8ups and Tom Shields like this.
  28. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,117
    790
    If you want to do another GB then get a new thread started and il be happy to do one. :)
    Trups
    gray99y, KrisKrk, jojo and 1 other person like this.
  29. JAAC UK
    70
    14
    You heard the man
    Sent from my SM-G950F using Tapatalk
    KrisKrk likes this.
