LED brake light upgrade.
ScottD3 Dec 30, 2010
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,122
    My 3rd brake light has been annoying me with one bulb not working or another.
    Take the light out and replace bulbs of just wiggle and the dead bulb will work again.
    Thought about buying the LED bulbs and decided not to. Wanted to do it my self. Bit more interesting and keeps me busy for a time.
    The below pics is my LED upgrade.
    The unit with standard little capless bulbs.
    1st, remove the outer red casing. 4 little clips, 2 on each side.
    2nd, remove the reflective strip. 4 little clips 2 on each side.
    You can see the bulbs and the thin conductive strip running down each side.
    Give each one a wiggle and a lift (gentle like) and it will come pop out.
    with out removed I test soldered a 5mm 12v red LED.
    It soldered on easy and fitted fine. So I did the other 9.
    When soldering the LEDs make sure they are low enough for the silver strip to clip back in to place.
    With it all soldered, clipped in and put back together I tested it out on the bench.
    It worked, so I fitted it back in the car.
    I'll get some night time pics later.
  2. hades-
    9,481
    646
    nice mod
    was woundering tho have you got any bigger pictures ?
  3. ScottD3
    15,161
    1,122
    Are you saying theses are to big? lol
    I got bigger if you really want bigger. lol
  4. hades-
    9,481
    646
    haha no there fine honest
  5. Broken Byzan
    13,237
    465
  6. ScottD3
    15,161
    1,122
    Nope nothing.
    If it does i'll report back.
  7. ScottD3
    15,161
    1,122
    Yup, got a DIS error over the weekend.
    Bugger :(
    Time to work out how to get the resistance correct and remove the bloody error.
    It looks nice and clean though. :)
  8. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    dont forget the night shots, how is it at night?
  9. ScottD3
    15,161
    1,122
    I'll get the pics of it at night tomorrow.
  10. ScottD3
    15,161
    1,122
    Night time pics as requested.
  11. rasA4
    3,287
    119
    seems bright enough?
  12. ScottD3
    15,161
    1,122
    It seems a little bit brighter than the normal bulbs.
    Can't really fault it just need to sort out the bulb out warning.
    Slowly working it out. Just need to get out to the car and test some ideas.
  13. ScottD3
    15,161
    1,122
    Update on this cause I got it working.
    I bought a 501 bulb resister off ebay, wired it in to the light and it all works lovely, no errors and 100% rear lights.
    Happy days.
  14. Yanzman
    Yanzman New Member
    15
    verry nice!!
