LED Ambient Light Unit fitted
jdp1962 Mar 6, 2013
  1. Rastamouse
    Rastamouse Welsh Audi Nut
    393
    19
    Did my rear ambient light conversion yesterday,dead straight forward. And quite pleased with the results
    Heres what i basically did.
    1.remove light unit
    2.find centre point of light housing,mark with pencil.then mark out position to drill holes-i went for 40 mm between centres of leds.
    3. Drill 2 x 5 mm holes and deburr
    4.fit leds and glue in place.
    5.once glue had dried.soldered the connections
    6. Re fit light unit.
    7. Sit back and admire youre handy work!!!
    I had a look at the guide that was posted further up this thread.
    Will get some pics up soon!
  2. ANDYTQ
    ANDYTQ Well-Known Member
    1,184
    105
    I might have a crack at the rears too.
    david a4 s line likes this.
  3. Danny-boy
    Danny-boy Member
    505
    24
    With the rears, where did you run the feed from the front unit? Or is there an ignition live at the rear light already?
  4. ANDYTQ
    1,184
    105
    I guess theres a live from the switch lighting ?
  5. Danny-boy
    Danny-boy Member
    505
    24
    Probably, but that would be permanent as the interior lights work without the key in?
    I don't know, I'm just curious.
  6. Rastamouse
    393
    19
    The rear map lights switches are illuminated,and only illuminated when your lights are switched on, just took a feed from them.
  7. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Managed to fit them in yesterday. Went for 6.5mm finishing hole size, de-burred using a small round needle file and then rolled up some Wet+Dry (P2000+P2500) to smooth out/polish up the inside edge. Only have a night shot of them illuminated unfortunately.
  8. tuffy
    tuffy Member
    314
    13
    Ordered mine today £14.50 delivered from main dealer
  9. AndrewS
    AndrewS New Member
    Hmmm, quite intrigued by this thread. I retrofitted the front LED module at the weekend and very carefully drilled 5mm holes bang in the centre of the locations in the light cover, only to discover when fully assembled that the LEDs sit several mm offset to the rear and as such, little light actually makes it out onto the dash & console - which rather defeats the purpose of the exercise. I'm planning to buy another cover and re-drill it with the holes biased towards the rear which should help. Can't really see how I could have got this wrong, there doesn't appear to be any scope to fit the module the wrong way round..??
  10. Danny-boy
    Danny-boy Member
    505
    24
    I drilled my holes the full size of the circle, I believe this is how they are done from factory.
    Just enlarge yours mate, saves buying a new trim.
  11. AndrewS
    AndrewS New Member
    Thanks Danny-boy. I've just had another look at it, fresh eyes and all... Being new to the forum, I'm almost too embarrassed to fess up, but in the interest of shared learnings, it turns out that you can mount the LED module the wrong way round...! Now repositioned and guess what - the holes line up perfectly! What a fud... :blush:
  12. Danny-boy
    Danny-boy Member
    505
    24
    Lol.
    That's all I have to say about that!!!!
  13. Tiffy
    Tiffy Active Member
    363
    89
    It takes a bigger man to fess up to these things.....lol........
  14. Danny-boy
    Danny-boy Member
    505
    24
    Very true.
  15. tuffy
    tuffy Member
    314
    13
    Hi guys
    My ambient
    lighting unit turned up today from the dealers.....i've had a look at it, directly at the led's and they sit slightly off line with each other, one appears lower than the other....is this right????
    Dont want to fit and i've got a dodgy one!! Can anyone confirm that theirs is the same please??
  16. pburv
    pburv Well-Known Member Team Glacier Gold Supporter Audi S3 quattro saloon DSG
    5,181
    10,814
    Hi tuffy. It,s ok they are meant to point in slightly different directions, to illuminate your gear stick and your radio area..:icon_thumright:
  17. tuffy
    tuffy Member
    314
    13
    Bingo!! i'll fit away! Thanks for that buddy :thumbsup:
  18. RJ44
    RJ44 New Member
    23
    Anybody know the part number for the Cab version, I had a look at the front unit and the LED lights or blanks for them are not in the centre like the pictures on here, they are at the sides...
  19. tuffy
    tuffy Member
    314
    13
    Fitted mine yesterday....I drilled 5mm holes to start with then moved to 6mm then finally 7mm. In my opinion the 7mm holes give a far better light in the car...
  20. ajax1976
    ajax1976 Well-Known Member
    1,272
    656
    Did my front and rears today, easy enough job but slightly disappointed in the output from them. Pretty sure the ones I had in my golf gave a better affect, the rear ones being particularly poor.
