Leaky roof
jonhun73 Apr 28, 2014
  1. jonhun73
    jonhun73 New Member
    Hi, can anyone help! I've got a4 cabriolet which has sprung a bit of a leak from where the roof meets the top of the A post! It seams to come in through the rubber seal! Drivers seat getting very wet! Any answers gladly received!
  2. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Check the drain holes on the top of the windscreen frame, you have to open the roof and they right on the extreme corners in the rubbers. I use plastic strimmer line to clean mine.
  3. jonhun73
    jonhun73 New Member
    Cool, thanks for that I'll give it a try
  4. DWH
    DWH Member
    50
    It will also be beneficial to use some silicone grease to lubricate the rubber seal all the way round, every 6 month's or so. It will help preserve the rubber and help the hood seat properly.
  5. TraceF1
    TraceF1 New Member
    Brand New A5 Cab SELine (March 2014) ROOF LEAKS. Garage took it back in still frickin leaks. Totally unimpressed could have gotten this from a £200 old knackered convertible tbh. Anyone any ideas? Just so you all are aware I hand wash car (takes 2 hours) and never once touched the roof or used a power wash on it :( very very disappointed.
  6. lewie
    lewie Member
    285
    Park it facing uphill
  7. DWH
    DWH Member
    50
    Can you tell where its leaking from ? Nearside, offside, header rail ? Any damage to rubber seals ? Or areas you can see where seals aren't flat. Try putting silicone grease around seals with hood open and then close hood. Then open hood and see if any areas where the grease hasn't squashed on the other surface.
    Has anyone heard about leaks through the actual fabric ? I think this is very unlikely though.....
    Best of luck and let us know how it gets resolved.
    DWH
