Leaking turbo pipe
ScottD3 Jan 20, 2011
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya saloon TDi
    15,164
    1,123
    I noticed some smoke coming out from under my bonnet today.
    I opened it up and noticed it was coming from a leaking pipe on top of the turbo.
    This is a older pic of the leaking pipe.
    Its leaking between the nut and the pipe.
    I'm tempted to just take a spanner to it but wondering if there is a washer or seal that could do with replacing.
    Any one got any hints or tips for doing this?
    A4 1.9 110 TDI 1998 AFN engine.
  2. tdia4
    tdia4 TDIPOWARRR
    613
    It's the oil feed pipe for the turbo, someones probally had it off before and not tightened it properly.
  3. aragorn
    18,577
    868
    yeh its just a compression fitting, try and tweak it up.
    I think you need to replace the line to that actuator as well!
  4. ScottD3
    15,164
    1,123
    I ordered a new union bolt thingy, that they said fits between the pipe and the turbo. I'll collect it next week if tightening it up does not work.
    Yeah, thats been on my list of things to do. That and another pipe or two.
    Will any rubber pipe do?
  5. Nilz
    11,364
    903
    Any rubber/silicone pipe will do dude :)
  6. ScottD3
    15,164
    1,123
    That nut is not moving.
    I tried tighten and nothing.
    I cleaned all the oil off to make sure that is where its coming from and it comes out of there rather fast.
    I'll have to wait till the part turns up next week before I sort this out.
    its leaking from top of the nut. I hope its the union and not the pipe it self.
  7. ScottD3
    15,164
    1,123
    Fixed the oil feed pipe leak today.
    It was the pipe at fault, the sealing ring at the end of the pipe was coming away from the pipe, letting oil through. I replaced the hole lot, all bolts, seals and pipe.
    Some pics.
    The old leaking part.
    New union bolt joint thing.
    New pipe
  8. nwmlarge
    nwmlarge flat out
    219
    was the pipe off the shelf?
  9. ScottD3
    15,164
    1,123
    Delivery.
    I got the union from VW and the pipe from Audi. lol
    3 times i went to a VAG garage and I never picked up any new pipe work for the thingy on top the turbo.
  10. netdef
    netdef New Member
    do you not find it is coming from the bottom of the turbo also? i have tightened my bolt up a bit and it stopped from the top but is still coming from the bottom.
  11. ScottD3
    15,164
    1,123
    Not seen any thing from the bottom pipe, only from the top.
  12. chud
    chud New Member
    21
    Hi Scott,
    you don't happen to have the part number for the union thingy do you?
  13. ScottD3
    15,164
    1,123
    I don't sorry.
    Any good VAG dealer should beable to tell you.
  14. gaurav2289
    gaurav2289 New Member
    I think first you tight the pipe as you can do it and after that it still leaking so you can use the rubber pieces and tight it surrounds the pipe, and as I can think the problem will be solved.
    ___________________________
    Leak Detection Specialist
  15. caistor_bmx
    caistor_bmx Sam
    The bottom pipe may be the same but you wouldn't notice as the oil isn't burning off the turbo as it drips on. I use braided oil lines on my mk2 golf, partly because its not standard and partly because they are shiney and look nice. A good hydraulic pipe shop (one in most industrial areas of the town) will make you one up for little money.
  16. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    I think it would be:
    028145786
