Leaking some sort of liquid (heater)
c3jys Apr 30, 2014
  1. c3jys
    c3jys Member
    121
    Hi yesterday when i parked up as engine was cooling i popped the bonnet and noticed there was liquid am guessing was water. Just droplets coming down heaters were on . So i turned the heating off and the drops stopped any ideas how or whats going on there ?? Dont know how else to explain this sorry
  2. <tuffty/>
    21,688
    4,119
    Air con normally causes this... end up with a damp patch under the car... its normal (assuming this is the issue)
    If it was a coolant leak it should be pink (Assuming you have G12 as coolant)
  3. c3jys
    c3jys Member
    121
    If it is the air con is it anything to worry about . Dont think i had air con econ switch was off
  4. <tuffty/>
    21,688
    4,119
    If econ is 'on' (red led indicator is lit) then air con is 'off'... is this what you mean?
  5. c3jys
    c3jys Member
    121
    No icon is not lit. Dosent that mean its not on .?
  6. <tuffty/>
    21,688
    4,119
    Press the econ button... if the switch's LED lights up then aircon is off... if its not lit up then aircon is on... please note this only swtich's the aircon compressor off/on... you can use Auto in ECON mode which means you have climate control but its not using the 'aircon' system to provide the cool air...
  7. c3jys
    c3jys Member
    121
    Will have a look thanks
  8. c3jys
    c3jys Member
    121
    Yes the light does lit so all this time ive been drivin with aircon on lol. So when its a cold night the econ switch shud b lit. Bit confusing this
