Leaking fluid... But from where?
V8Guzzler
Nottingham
After a drive up the motorway today when I parked up I noticed fairly rapid dripping from the front valance from the engine bay just under where the fog light is. It was not teaming out but it was a good drip drip drip. I thought it may be the pipe that feeds the headlight washer, so I topped up the washer bottle drove home. No water lost from the water bottle... Checked coolant level this hasn't moved either. I am baffled... Any ideas?
Is it water or oil? Could have a cracked intercooler you get a bit of oil mist in there from the crank breather
it still could be the washers mate, last year my ones froze up and busted the seals, i was only losing water after id used them, then after enough pressure had dropped the dripping would stop,
This sounds very likely - she is in tomorrow having brakes checked so will have a nosey at the washer pipes - cheers
Serviced today - still leaking from headlight feed offside - how easy is this to get to? Any how to guides on this at all anywhere?
