Leak under car - normal?
razza1 Feb 19, 2011
  1. razza1
    razza1 Well-Known Member
    3,075
    829
    I've noticed quite a bit of oil like liquid under the car:
    I've run my finger through it and its not oil coloured, it's clear, it just has a sheen to it like oil. My first thought was it's the aircon condensing, which you usually get a bit of, but not to this extent...
    It's dripping from pretty much the back of the undertray
    Any thoughts?
  2. razza1
    3,075
    829
    but only when the engine's on, had a look through the engine bay but can't see anything obvious
  3. hades-
    9,481
    646
    well it could be from anywhere as it will collect on undertray and drop at the center
    is your coolant lever droping ?
  4. hades-
    9,481
    646
    can i see a pic of under your bonnet
    i wana se how you got the rs4 covers to fit
  5. razza1
    3,075
    829
    this is the old car with covers fitted, same as the new one:
    will check the coolant level in the morning
  6. razza1
    3,075
    829
    it is actually only one cover...
  7. hades-
    9,481
    646
    cheers for the pic
    i thought you ment you had the carbon covers fitted
  8. razza1
    3,075
    829
    nope, haven't got that kind of money lying around lol :)
  9. razza1
    3,075
    829
    coolant level's fine, hasn't been leaking further sat on the drive, think it must eb the aircon..
  10. Wrath
    Wrath Well-Known Member
    1,196
    42
    I had a similar problem that turned out to be a cracked pipe on the power steering.
  11. razza1
    3,075
    829
    Just had an audi technician out, they've noticed the transfer box is weeping, thinks it's a leak from there.
    I also get a kind of juddering when accelerating hard, but not sure if that's normal for quattro as have nothing to compare it to (it's the first quattro I've had)...so they're going to check that out also for me.
    It's under Audi warranty and recovery, so they're taking it away for me and giving me a replacement car until it's fixed, glad I had that as could be expensive (maybe), although have only had the car for 4 weeks... :(
