LCR Brembos
Pat Sep 28, 2007
  1. Pat
    Pat Member
    515
    I have sourced some brembo calipers/discs and pads off a Leon LCR.. But i haven`t got any brake lines.. Do they have to be made up or will the standard leon flexi hoses fit my 2001 S3?? I can have some made if need be but need to know what ends are on each end..
    Pls help!!!
  2. Stewart
    Stewart Member
    705
    10
    Standard Leon hoses will be fine.
  3. Aky
    Aky Aky
    1,512
    Would Standard Leon ones be ok or would they need to be hoses off the Leon Cupra R??
  4. Pat
    Pat Member
    515
    I know the caliper end fitting will be the same but wondered if the other end would be the same.. If i can get one as a pattern i have them made up..
  5. Pat
    Pat Member
    515
    I would say the fittings on cupra r is different as it has brembos where the cupras run same brake setup as s3 (I think)
  6. jcs356
    jcs356 Brum brum
    2,723
    64
    Yeah, you need the LCR ones. As you say, the LC has similar brakes to the S3, on the LCR has Brembos. Also see the thread from a couple of weeks ago about routing of the lines - you may have to rotate the bracket holding the lines through 180 degrees so it is behind the strut (as you look at it from the wheel) rather than behind it.
  7. browner01
    browner01 Member
    are there any places to get the LCR brembos? i have searched around for them but no success
  8. Pat
    Pat Member
    515
    PM me.. i`ll find ya some..:o.k:
  9. jcs356
    jcs356 Brum brum
    2,723
    64
    Scrapper or fleabay?
  10. jcs356
    jcs356 Brum brum
    2,723
    64
  11. Aky
    Aky Aky
    1,512
