LCR Brembo dismantling help......
Dani_B19 Sep 18, 2012
  1. Dani_B19
    9,172
    363
    Right, to cut a long story short the bridging brake lines that supply brake fluid to the other side of the caliper, well they are shot, on both calipers, had a very bad accident on my behalf :(.
    Anyway, i need new lines but can i f*** get the old ones out, i know the brake nipple is a 11m head but its like monkey metal, ive used penetrating fluid, blow lamp, mole grips, you name it ive tried it but the god damn nuts will not budge, its to the point theres hardly any material left to grab lol, their fused in.
    Any ideas on what to do to get them out?
  2. <tuffty/>
    21,016
    3,780
    Clamp the bleed nipple in a vice and turn the caliper...
  3. Dani_B19
    9,172
    363
    Ooh i like that one lol, so cut the pipe of flush then clamp it in best i can? Its not actually the nipple PT its the bridging pipe nut thats stuck.
  4. <tuffty/>
    21,016
    3,780
    Same principle... more clamping force with the vice and more leverage... still take it easy though...
  5. Dani_B19
    9,172
    363
    Yeah i know what you mean, if that doesnt work i dont know what will, its like they've cold fused together, even mole grips wrapped around tight wont budge, just strips the nut.
  6. <tuffty/>
    21,016
    3,780
    A little heat on the caliper might help... just don't use too much
  7. vroomtshh
    vroomtshh Active Member
    362
    49
    If your in no huge rush, chuck them in a bucket of diesel for a week. I do that every time I'm stripping a set of calipers. It frees all the bolts off nicely. If you go at the crossover pipe too hard, it tends to just rip the thread out of the caliper
  8. Dani_B19
    9,172
    363
    Argh thats a nifty trick! Does it damage the dust/piston seals though? Also does it strip the paint off?
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    If you get stuck Dan take a ride up to my workshop and we will get the buggers out.. :icon_thumright:
  10. vroomtshh
    362
    49
    Doesn;t strip the paint, and hasn't damaged any of the seals that I've done
  11. Dani_B19
    9,172
    363
    Cheers dave, ill give the vice trick ago tomorrow and see how it goes if not i may take you up on that offer :).
  12. Dani_B19
    9,172
    363
    Cheers vroom.
  13. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Dan can you not get a socket on to them once you have cut the pipes? That's what I done
  14. Dani_B19
    9,172
    363
    Could try it but mine seem stuck solid mate, were yours tough to remove? Also where did you get ya new lines from?
  15. jojo
    28,859
    3,518
    Am I reading this right? Using the pic I robbed off another thread(Thanks Alex), you want to take the pipe on the far left odd the pic off? Where the tag is attached to? Does it ever need to be taken off?
  16. s3 Hoggy
    1,716
    158
    I made/had new ones made up, very easy once you have the flairing tool and some 4mm copper tube! Mine were soaked in plusgas and they were not a problem with a socket. The old ones on mine looked tiered and I just wanted to get on with refurb and splitting down so I just cut them
  17. Dani_B19
    9,172
    363
    What size are the threaded nuts mate?
    Yup jojo, mine had a accident :(.
  18. jojo
    28,859
    3,518
    Fair enough mate, you aint had any luck with this car have you?!
  19. s3 Hoggy
    1,716
    158
    Just had a look in the garage mate and I can't find the spares I had! Shame :( I'm pretty sure the that they are M10x1 thread
  20. vroomtshh
    362
    49
    M10 x 1.0 for the thread
  21. s3 Hoggy
    1,716
    158
  22. Dani_B19
    9,172
    363
    No jojo i dont have, its has its ups and downs but to be honest thats what makes me love amd respect my car even more, this car has been a massive learning curve over the last 3 years and to be fair i wouldnt rwally change it, apart from various twats damaging it lol, but all in all i love it all.
    Thats the size i thought they were, what aboutthis full kit from the same seller:
    http://item.mobileweb.ebay.co.uk/viewitem?itemId=220701934905&index=0&nav=SEARCH&nid=95299917162
  23. s3 Hoggy
    1,716
    158
    Looks spot on dan and the ends of the tubes have already been flared, remember though you can't just bend the pipes with your hands as they'll kink. Easy way to bend them is to softly roll the corners on a socket. Take it slow and you won't kink them
  24. Dani_B19
    9,172
    363
    Good job you mentioned that mate or id have been buying another set haha.
  25. IrishDave
    IrishDave Active Member
    682
    45
    Use a blow lamp to heat the pipe before trying to bend it. Makes it a lot easier to do and go slowly at it using a bar to roll the pipe around and re-heating the pipe all the time. Had to do this only yesterday after damaging one of the pipes(sorry S3Dave after doing a great job on refurbishing the calipers).
  26. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,261
    357
    that's the kit i bought
    beware of the bolts that bolt the two halves of the caliper together though, they are a tad long...
    fouling the carrier bolts...
    i only bought the kit to replace the stainless pad shim bolts. The standard ones are also made out of chocolate and PITA to get out
    I still have the fluid transfer pipes in the garage i think from that kit if you want? Unless Dad has had a tidy.....unlikely
  27. Dani_B19
    9,172
    363
    How did you get around the bolts been longer mate? Also did ou use the bleed nipples from the kit?
  28. Dani_B19
    9,172
    363
    Also dont want to sound slack but what the shim bolts you talk of? What are they for?
  29. Alex C
    3,261
    357
    see the metal plates at the bottom of the calipers...
    these are the pad shims
    How did i fix the problem of the long bolts? ... used the old ones :)
  30. Dani_B19
    9,172
    363
    My brembos dint have them, do they come with the pads? Also did you use the new bleed nipples alex?
  31. Alex C
    3,261
    357
    no, they are part of the calipers. Yeah i replaced the bleed nipples - its advisable. But again be careful, i think the bleed nipples and other bits are made out of chocolate to make cross threading the aluminium calipers difficult - the threads of the fixings will cross thread before the caliper internal threads. Problem with this is that the fixings have a habit of shearing i have seen - i was lucky though
    are you doing a complete teardown?
  32. Dani_B19
    9,172
    363
    Nice lol. Im struggling to strip the buggers, everthings seized lol.
    Uup mate, total refurb apart from pistons. Can you have a look and see if you have those pipes still mate?
  33. Alex C
    3,261
    357
    yeah, as suspected the garage is a tip and the pipes were where i'd left them
    let me know their new home
  34. Dani_B19
    9,172
    363
    Right, so was wrestles and nipped into the garage.
    The brembos do have shims, its just their that black you cant seem them at first glance lol.
    Secondly, i know why the pissing pipes are so hard to remove, i did the trick or socketing them and blow lapping them at the same time, once out i saw that the previous twating owner had ****ing cross thread the fittings, ****ing ***** monkey.
    So half the threads intact but the rest is mush, whats my options? What this helicoiling is it? Heard of this used before when people have said sumets cross threaded etc.
  35. Alex C
    3,261
    357
    the cross threaded thread is drilled out so the hole is slight bigger and then you wind a helicoil into the hole which is just a helical coil (obviously :)) which matches the thread of the original threaded hole
    I have read that a helicoil is stronger than the original too because of the way the torsional force is distributed - maybe rubbish though
    <a href="http://www.youtube.com/watch?v=RFYa6sjhh_E">
  36. Dani_B19
    9,172
    363
    Are thanks mate, any idea wheres the best place to get this done?
  37. Alex C
    3,261
    357
    i would find a local machine shop. I never had to helicoil mine though. I managed to get away with it. See if anyone else has an opinion on helicoils though as im not really qualified other than i know what they are
  38. Dani_B19
    9,172
    363
    Haha no worries mate, thanks for all ya help, been much appreciated fella.
  39. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Worst case you can buy bleed nipple inserts after you get the calliper retapped. Search on ebay for brembo bleed nipple insert.
    Mine were an absolute pain too, but luckily my threads were salvageable with new nipples
  40. IrishDave
    682
    45
    Dani. Let me know if you manage to get new oil seals for the pistons as I was unable to get them when Dave was refurbing my calipers. Seat did not stock them on their inventory and Brembo would not sell them as they recconed it is a safety issue and will not sell you the parts only a new caliper. I have another set of LCR calipers sitting in the house and might refurb them also.
