LCD dead pixels, anyone used these guys?
aidank1981 Dec 22, 2008
  1. aidank1981
    aidank1981 Member
    252
    Hey all,
    Anyones used these? seems to be a commen problem, theres a thread on here from 2005 but nobody mentioned anything other than an audi replacement for mega money? thought id see if they got recomended or slated before contacting them!
    link is
    http://www.led-s.co.uk/Dashboardpixelrepairs.html
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,771
    31
    Not heard of anyone using these guys, most people who have had the repair done have used BBA-Reman. Looks like LED-S's price is around the same. Worth emailing them both for a quote.
    I've used BBA-Reman for an ABS ECU repair and highly recommend them as they had the repaired unit back to me within 3 days of me sending it.
    As you will be unable to start the car when you send the dash cluster off, a quick turnaround is very important!
  3. Mr K
    Mr K Member
    335
    looks good, i was wondering about getting mine done - but isnt it tied into the imobiliser on the facelift cars? scared of them screwing it up - it could cost £100's to get audi to put it right!
  4. aragorn
    18,138
    765
    it is tied to the immobiliser (well the immo unit is built into the instrument cluster) however its probably not something to be concerned about and can be fixed yourself with the vagtacho software should they knacker it and you require a new cluster...
  5. Dan Yeates
    Dan Yeates Audi S4 B5 Avant
    44
    Their website says this:
    Surely we can find out where the screen comes from, RS components sell several LCD screens, one of them must fit...
    Here for example: http://uk.rs-online.com/web/search/...unt=193&Ne=4294957561&N=4294767569+4294955787
    Then it must just be a case of swapping the screen over, those of us with good soldering experience could easily do this for a fraction of the cost and hassle.
  6. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    Discussed here before :eyebrows:
    Linky
  7. moschino
    moschino Member
    252
    Why not purchase a replacement dash from a salvage yard and swap the DIS conponent over?
    No messing about with the immo.....
    Try the following contact, they break several cars per day and can post to anywhere in the UK. Have used them several times in the past and always been good.
    Make sure you let them know the part number you want, also what age car it is needed for.
    Overton Dismantlers
    Overton Garage Ltd
    off Dyce Drive
    Aberdeen
    Scotland AB21 0EQ
    Tel: 00.44.1224.722354
    Parts Fax: 00.44.1224.775451
    General Fax:00.44.1224.722457
    Email : sales@overtongarage.co.uk
    Regards,
    Jim.
  8. rasA4
    3,287
    119
    i think that would be a waste of time as the DIS could be in a worse state than your existing one, also you still have the same soldering issues
    you would have to de-sloder you old one and de-solder the scrappy one and re-solder to your existing one.
    the main issue i think is the ribbon not the actual DIS screen itself?
    this is a common problem with DIS i have a facelift 2000 year with the same issue, so even breaking from a later car would not avoid this.
    :blink:
  9. Siena
    Siena Active Member
    2,626
    Not that straight forward.
    A buddy of mine looked into it a while back - you'll need to buy quite a few to make it worth while, he was told they would do a minimum of 25 units. Otherwise, it was going to cost him more to buy just one, to replace his, than it would cost to get it repaired by companies like have been listed here.
    So, it'll be best to organise a group buy.
    Problem is, with group buys, folk are all too keen to say "I do", till it comes to making their deposits, then it rapidly becomes long stories - my car needs new tyres, I need a new Garmin, my cat ate my dog etc etc.
    Basically, the long version of, "not sure I can afford it."
  10. Siena
    Siena Active Member
    2,626
    @ RAS: The fault lies within the LCD panel itself, not the ribbon cable.
  11. rasA4
    3,287
    119
    thanks for clarifying Siena,:salute: wasnt sure that's why i put a '?'
    still not worth buying a unit from a scrappy
    good idea about a group buy, however as you say people can back out last minute and leave you holding the can.
  12. rasA4
    3,287
    119
    Trying to to a group buy for 25 cars would be too difficult to organise, me thinks.
    out of interest what's the Ballpark figure Siena?
    mine is not that bad at the mo though
  13. Siena
    Siena Active Member
    2,626
    Can't remember the figure - it was in $.
