Launch control
motionlee Mar 22, 2010
  1. motionlee
    motionlee Member
    98
    Hello i wonder if Launch control programme can be added to the 3.2 dsg 04 plate via vagcom or does the dealer have to do it ? and what cost would be involved
  2. motionlee
    motionlee Member
    98
    A free bump for myself
  3. beanoir
    beanoir Large Member
    2,171
    31
    I have never seen anybody mention launch control on this forum, but i'd be interested in seeing peoples responses..
  4. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,230
    153
    Hi Lee
    Launch control is std on your 04 3.2 DSG.
    Switch off your ESP. Put car in S-Sport mode. hold it on the brake and give it some revs, take foot off brake at about 2.5 -3k revs.
    Personally i wouldnt do it too often !!! seems like one strep away from an exploding gearbox to me...Mine takes off like a scolded cat but there is quite a bang through the drive train.....:scared2:
    Its not so much launch control as auto clutch dump....
  5. motionlee
    motionlee Member
    98
    Hi Paddy just seen your post, thanks for the reply, well i think i dont have it as when i switch esp off in s mode with the brake on the car wont rev over 1200 rpm, so something not right there.
    The revs have to go to 2400rpm for it to work.
  6. paddy
    5,230
    153
    Lee
    If it will not rev then you need to push the brake harder
    It works in the following way.
    At standstill, you take off ESP, put the car in Sport, put your left foot on the brake, put your right foot on the gas the revs should level out at about 3000 and when you are ready to go take your foot off the brake...
  7. dc240969
    dc240969 Member VCDS Map User
    925
    WOT controller
  8. Joe90k
    Joe90k Speed doesn't Kill!
    227
    AFAIK if the car has had the DSG update then launch control has been taken off. My car definitely doesn't have launch control as I tried to make it work for hours a few months back and nothing. I eventually phoned Audi and asked a technician who told me if I had full dealer history that it would have been updated and been removed from the car to stop the DSG prematurely failing. Mine also will not rev past 1200RPM and don't press the brake pedal too hard you will snap it lol
    Hope that helps.
  9. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    Oooohhh have to try this lol, niver heard of this before!!!!
  10. garyburton29
    garyburton29 Member
    147
    It tells you about Launch control in the owners handbook:readit::)
  11. paddy
    5,230
    153
    sorry Joe..we were talking 3.2's
  12. Joe90k
    227
    All DSG's had/have launch control unless you have Audi service where it has been coded out with an DSG ECU flash. Mine has been updated. I'm sure that's correct as I have two very reliable sources, one an Audi master technician.
    Joe
  13. paddy
    5,230
    153
    Maybe Joe but in the hand book, only the 3.2's have it enabled from the factory. Its an option on all others.....and a Audi master technician. is not a reliable source for anything :faint:
