Last SDS Questions I promise...
WelshWoody83
South Wales
Hello as you may have read i recently tried the SDS hack.
I still cant get it working properly so Im thinking of reverting back to just bluetooth for the phone only but wanted to check one last time if theres anything Ive done wrong?
Th mi from the roof goes as follows.
Pin 1 of mic to Pin 1 of block C
Pin 2 of mic to Pin 7 of block C
Wires that used to go from the Bluetooth unit to the mic now go to Pins 4 and 10 of block C
Thats how I have it set up. If i swap the wires for 1 and 7 around the mic doesnt work, so I assume I have those rite. The same goes for if I swap the wires for Pins 4 and 10.
If I try to use the PTT for anything other than the phone it says option not available.
The problem now is that when I press the PTT and say Select name it now says "option not available" but if I say "Radio" it dials my home phone number?
Im thinking maybe its best I just go back to having bluetooth only, wired straight to the MIC and forget about SDS, even though the options are available through the RNS-E it simply wont work.
Is there any coding that needed changing?
Anyone else have this problem?
Chris
Hi Chris,
I'm going to be attempting this today (joy!) and as far as I'm aware, if you have factory bluetooth and RNS-E setup then there is no need to recode via VAG COM. Most of the guides I've seen have started from the base point with factory bluetooth and RNS-E and have not involved any coding, whilst this may not help, it may allow you to rule recoding out for now?
Do you have BOSE? Apparently you need to move 1 wire in the Quadlock connector that plugs into the back of the RNS-E althought I've yet to find direct instruction on this...
Regardless if you have factory BT/RNS-E, if its not been wired for SDS from factory, you have to code the systems for SDS bottom line.
Woody whats your coding for BT, MFSW & RNS-E, a log of those modules may help.
Thanks N, managed to find something on this where they suggest the recoding that needs to be done is to the Bluetooth Module only and the changes to the coding = from 1xxxx to 1xx0x to enable SDS.
I guess it depends on the config of other modules... guess i need to get me VCDS/VAG COM
I didnt have either RNS-E or Bluetooth as standard and I believe the guides you say about are the ones I read before I started posting on here about the SDS hack myself . Thank you though.
Nigel I dont have access to VCDS at the moment but will ask the guy next door if i could borrow his sons again. I have a log from a scan I ran before giving it back though but not sure if that would show what needs to be known or not? Im pretty sure that this was the first scan I did after finding my bluetooth fault, it had been coded with k-line diagnostics instead of can bus at the "Audi Specialist".
Here it is anyway...
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: None
Part No SW: 03G 906 021 TP HW: 03G 906 021 AN
Component: R4 1,9L EDC 000SG 2595
Revision: --H09--- Serial number: AUX7Z0H9FN60G6
Coding: 0000071
Shop #: WSC 06314 000 00000
VCID: 800B0433AA93
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 13422012092700FDC81304E4901D00813800
VCID: 74E3D8E36E2B
Address 08: Auto HVAC Labels: None
Part No: 8P0 820 047 B
Component: J255 Klima Man H07 0030
Shop #: WSC 00000 000 00000
VCID: 2F69178FC78D
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008984701
Coding: 11A82F81B0141380EF00001C0000000000084E1564010403002800000000
Shop #: WSC 06314 000 08192
VCID: 489B5C134223
Part No: 8P2 955 119 F
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030374A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 499D59175929
Driver's Airbag Crash Sensor:
Serial number: 3572DRB400008059011A
Passenger Side Airbag Crash Sensor:
Serial number: 3582DRB400008058710G
Driver's Rear Airbag Crash Sensor:
Serial number: 35128RB4000044A0A249
Passenger's Rear Airbag Crash Sensor:
Serial number: 35228RB4000044B38017
Driver's Front Airbag Crash Sensor:
Serial number: 35547RB40000464977FW
Passenger's Front Airbag Crash Sensor:
Serial number: 35647RB400004649750G
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002012
VCID: 418D41376119
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2249H006007530
Coding: 0004428
Shop #: WSC 00011 888 96745
VCID: 397D29D709C9
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0893003FA
Coding: E9807F064006022103
VCID: 356525E725D1
1 Fault Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 120022 km
Time Indication: 0
Date: 2011.06.04
Time: 12:08:28
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H18006 Serial number: AUX7Z0H9FN60G6
VCID: 397D29D709C9
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 Q HW: 8P0 035 192 Q
Component: RNS-E HIGH EU H76 0650
Revision: 05S Serial number: AUZBZ7J0907106
Coding: 0205715
VCID: 3D753DC71DE1
2 Faults Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 60
Mileage: 119956 km
Time Indication: 0
Date: 2011.06.02
Time: 13:43:06
Freeze Frame:
Mileage: 120020 km
Count: 406
Clock: 12:08
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 2
Mileage: 119803 km
Time Indication: 0
Date: 2011.05.25
Time: 12:07:36
Freeze Frame:
Mileage: 119800 km
Count: 2505
Clock: 12:07
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000692
VCID: 43814B3F7B05
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 232 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5F069BFC6F
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D0985054C9FC637
VCID: 43814B3F7B05
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000692
VCID: 448348237E0B
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0205715
VCID: 3D753DC71DE1
2 Faults Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 60
Mileage: 119956 km
Time Indication: 0
Date: 2011.06.02
Time: 13:43:06
Freeze Frame:
Mileage: 120020 km
Count: 406
Clock: 12:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 2
Mileage: 119803 km
Time Indication: 0
Date: 2011.05.25
Time: 12:07:36
Freeze Frame:
Mileage: 119800 km
Count: 2505
Clock: 12:07
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 418D41376119
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 428F4E3B641F
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005259217
Coding: 0011822
Shop #: WSC 98111 611 11111
VCID: F4E358E3EE2B
End ---------------------------------------------------------------------
Coding: 0002012
VCID: 418D41376119
C00,Steering Wheel Electronics (J527) Coding
00?xxxx: Transmission
0 = Manual Transmission
1 = Automatic Transmission
00x?xxx: Steering Wheel
0 = Spoke Steering Wheel without Tiptronic without Multifunction
1 = Spoke Steering Wheel with Tiptronic without Multifunction
2 = Multifunction Steering Wheel for Radio Operation
3 = Multifunction Steering Wheel for Radio/Telephone Operation
4 = Multifunction Steering Wheel for Radio/Telephone/Voice Control Operation
5 = Multifunction Steering Wheel for Radio/Voice Control Operation
00xx?xx: Additional Equipment
+1 = Tiptronic (Shift Paddels)
00xxx?x: Board Computer / Cruise Control System (CCS)
0 = w/o Board Computer and w/o Cruise Control System (CCS)
1 = with Board Computer and w/o Cruise Control System (CCS)
2 = w/o Board Computer and with Cruise Control System (CCS)
4 = with Board Computer and with Cruise Control System (CCS)
00xxxx?: Rear Wiper
1 = Rear Wiper not installed
2 = Rear Wiper installed
Spot the issue?
656
933
19
