Laser Star Pro
I used to run a few "parking sensors" in previous cars, work very well if set-up right.... it's a big grey area regarding the law though.
Some numpty kept driving past a camera van at 100+ with a finger out the window with one of these things:moa:, he got done with Trying to pervert the court of justice FWIKR:asskicking:. Since then if a camera van gets the Jammed indicator from a car or an unable to read speed etc, you normally get a knock at the door from the BIB.
Best advice, is if you fit one, fit removable connectors to the sensors and if you have a trigger, remove sensors for a few weeks.
The law is usually pretty clear on all this sort of stuff and in any case what would you need it for?
One other point is that by the time most detectors bag the laser, the laser has got you as well.
There are some that turn off just after jamming. So the Police get a bad read, try again and get a good one. But by then you've slowed down. The other two main laser jammers are the Laser Pro Park and Laser Interceptor, although I'm not sure if the Laser Pro park is still manufactured.
This is Ilim were talking about...........the best driver in the world apparently......snigger!!! who does NO wrong on the roads.
837
792
jamiekip
J
