Laptop to tv?
kev1000 Sep 24, 2011
  1. kev1000
    kev1000 Member
    209
    Can anyone tell which cables I need to view what's on my laptop on tv?
    I have a HP 550 laptop and the tv has the green,blue and red inputs + the usual inputs.
  2. gary3306
    gary3306 Active Member VCDS Map User
    989
    40
    If your laptop has got a HDMI socket and so has your TV, then thats the best way. HDMI lead. Or failing that, VGA connector
  3. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Has you T.V got a VGA cable port in the back of it? Something like this:
    That is how I connect my laptop to my T.V.
  4. kev1000
    kev1000 Member
    209
    Thanks for reply's guys.
    Yeah the laptop has a connection like that and the tv has a similar one but smaller and doesn't have the screws.
    So can I just set external display on in laptop settings and that's it?
  5. kev1000
    kev1000 Member
    209
    Also what are the y pb pr cables for?
  6. kev1000
    kev1000 Member
    209
    Ok, what I gather is, laptop has VGA connection and the tv has hdmi connection.
    So there's no VGA on the tv.
    Can I connect VGA to hdmi?
  7. Kaibo
    Kaibo Member
    358
    14
    Hi, check maplins as I'm sure they'll have a cable you need, or possibly the bay, VGA to HDMI cable, not 100% on weather you'll have sound but it's a start.
    Cheers Kai
  8. kev1000
    kev1000 Member
    209
    Thanks, doing a bit of research and I think I might need a convertor?
  9. Kaibo
    Kaibo Member
    358
    14
    Basically the cable is the converter but you have to check your video card to see if it will output digitally through the VGA port, otherwise its a tad more expensive for a box of tricks to do the job. I should imagine most laptops would cater for this but check first anyway.
    Cheers Kai
  10. kev1000
    kev1000 Member
    209
    Cheers Kai, how do I check the VGA card for tv output?
  11. Kaibo
    Kaibo Member
    358
    14
    That's a good question, I think you have an Intel GMA X3100 card, by what I've read it doesn't have tv out, you could try a VGA to RGB for £3 and test your arm.
    Cheers Kai
  12. kev1000
    kev1000 Member
    209
    i actually ordered vga to rgb cable on saturday so hopefully it will work but knowing my luck i doubt it.
    thanks for the help.
