Lane Change - change the number of flashes from 3 to 5.
h5djr Aug 15, 2011
  1. h5djr
    9,383
    1,727
    I've seen on the A1 Forum (which I have started to look in to because my wife has a new A1 on order) that on the A1 you can change the number of times the indicators flash using the Lane Change from 3 to 5.
    The details given are:
    • [VCDS] Indicator Soft Touch
    • Sets the number of flash operations of soft touch turn signals
    • Control unit "09-Central Electric">> "Adjustments">> "Comfort turn signal (Cycles)
    • Adjustable: 1-5x
    • Default value: 3 times
    Does anyone know if this is the same on the A3.
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    Maybe on your 8P3 Dave, ive never seen the option on my older A3 though.
  3. slade777
    slade777 Member
    763
    I saw this option on my VCDS the other day for my MY10 car but kept mine set to 3.
  4. h5djr
    9,383
    1,727
    I've just had a look using my VCDS and their is a controller listed as 3C-Lane Change but when I click on it I get the message "No Response from Controller. I assume therefore that it cannot be changed on my 2009 A3. Shame the 5 flashes would be nice.
  5. paddy
    paddy Audi=No fault code, no idea
    5,168
    136
    I think i can change mine via the DIS...once i have owned it for a couple of years i might read the instruction........but then probably not :)
  6. N8
    17,163
    718
    :laugh:
  7. quattro81
    quattro81 All the gear.. No idea
    970
    90
    Afaik you can turn the lane change thingy on and off with the dis.. Don't think you can change how many times it flashes without vcds? Is 3 not enough, then..? Just change lane a bit quicker??
  8. h5djr
    9,383
    1,727
    Normally three is enough but the little extra is always useful as a lot of drivers seem to drive along with their brains in neutral.
  9. audigex
    audigex Active Member
    594
    45
    You could do 3 flashes twice and pretend? :)
    It's definitely not available on the older A3s, I doubt on the newer ones either. You can disable it (soft touch just gives one flash not 3) but not modify the number.
  10. Khufu
    5,704
    31
    I too have the option for switching the comfort function off & on from within the DIS but not to alter the duration.
  11. paddy
    5,168
    136
    I think 3 is enough because i use it a lot on roundabouts .....Yup..I'm the guy that still uses indicators on them :)
    Point is going right at a roundabout you want to indicate right to go round.....then left to leave the roundabout and 3 flashes is about right in convenience mode to do that. you dont want to be still flashing right as you turn left to leave :)
    also i would say when overtaking say a cyclist, 3 flashes indicates an overtake. 5 or more would be almost indicating you are about to turn right and scare oncoming traffic to death :)
  12. paddy
    5,168
    136
    See !! i knew it was not worth reading the instructions :)
  13. Khufu
    5,704
    31
    I never used to have it LOL - got it when I upgraded my CE module for my bi-xenons LOL
  14. fuzion
    fuzion Active Member
    225
    150
    43
    I did some research into this not long ago. Unfortunately not possible on pre 09 models and even some 09 up still not possible.
    Sucks as I was hoping to also change it!
  15. NHN
    29,329
    1,708
    Lane change module is associated with the lane change assist Dave that has warnings built into side of mirrors on say newer A4, A5 etc.
    Still need to find out if it has any interaction with dis, as I'm assuming its coded into door modules aswell.
  16. quattro81
    970
    90
    I agree with all you have said here paddy.. Its obvious from this you have proper biker road sense.. All joking aside, if more people drove like this, the road would be a lot safer (and I wouldn't have wheels for legs)
